Fuel Pump Trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2006, 08:19 AM   #1 (permalink)
Koo'rolla Lives Forever
New'rolla's Avatar
View New'rolla's Photo Gallery
AE92 Fuel Pump Trouble
here's the deal, my fuel pump wont turn on, the pump itself is good (i ran it to the battery and it came on) but i wanna know if there's a problem with the power wire running it.. where can i find the relay's and all the wiring, i fallowed the wire to the dash (i have no interior in the car..) and i dunno where the relays are...
could someone post a pick of what i am looking for? the relay must be bad. or the wires got a break in it.. either could be BAD.. but w/e i need to see if that's the only problem
QUESTION:
WHAT DOES THE FUEL PUMP RELAY LOOK LIKE? AND WHERE IS IT LOCATED IN THE COROLLA GTS AE92
New'rolla is offline   Reply With Quote
Old 05-14-2006, 01:43 PM   #2 (permalink)
Gameroom cash: $134355
it's called the circuit opening relay
the first thing to check is by having the key in the 'on' positon then go push the AFM door open..... the fuel pump will only be on if the AFM door is open....
Old 05-14-2006, 06:02 PM   #3 (permalink)
New'rolla's Avatar
is that the door inside of the air box? just asking.
i don't have any other ideas of what the AFM door is other then that door. and here's how it all happened,
when i first got the car, it hadn't been driven/started in like 4 months.
i drove it home n/p, and it sounded amazing. when i got in it to go for a ripp i revved it up and the engine died, and hasn't started again since, but we couldn't here the fuel pump... so i dropped the tank and found the fuel pump works. we hooked it up..
but the wires had no power comming through them. so i ened to replace them. any ideas where the other end goes (not the tank end) and where i can find the start of the wires?
1MZ-FE fuel pump pressure hksboost Camry & Solara Lounge 21 12-13-2010 03:54 PM
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
Fuel pump rewire. 97camryman Camry & Solara Lounge 2 03-08-2006 09:46 AM
Walbro Fuel Pump, turbine pump? almc2242 Hardcore Tech and Competition 13 02-19-2005 09:08 PM
LS 400 no power to the fuel pump?? 70 140 General Lexus Discussion 2 02-04-2005 08:42 PM
