20v clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2006, 05:38 PM   #1 (permalink)
View browner's Photo Gallery
AE92 20v clutch
Will a 20v clutch bolt up to a 16v redtop? Need to know ASAP!!
browner is offline   Reply With Quote
Old 05-15-2006, 05:47 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I believe its only the flywheels that are different, clutch should bolt up.
Old 05-15-2006, 09:14 PM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Clutch and Pressure plate will - Flywheel wont..
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 05-16-2006, 02:15 AM   #4 (permalink)
Gameroom cash: $134355
um, yes it will
all 4ag's use an 8 bolt flywheel with the same pattern.... hence why any ae86 can take a blacktop 4age and use a stock 200mm clutch (to fit into it's tranny)
so.... the 20V came with a 212mm flywheel/clutch/pp combo... the same as any 88-89 mr2, 88-91 corolla gts, and the 7afe's..... (except the 7afe has a diff flywheel... 6 bolt like the 4afe)...
the only A series motor that came with a specially sized flywheel that wasn't used on any other motor was the 4agze.... it's larger than the 212mm (220 or 228mm depending on year) and smaller than the turbo mk2 mr2's 23Xmm flywheel....
4agze clutch fits a 20v 4age??? top-speed Archived Corolla threads 13 09-24-2006 03:35 PM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
Help! What clutch for the 20v silvertop? aaron7 Archived Corolla threads 11 06-11-2005 11:08 AM
