93 1.6L bad water pump - t-belt cover removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 02:01 PM   #1 (permalink)
View island cruiser's Photo Gallery
USA 93 1.6L bad water pump - t-belt cover removal
greetings-
i just got a 93 Corolla and the water pump is leaking pretty bad. started to pull everything but how do you get to the one t-belt cover bolt that's hiding behind the AC idler?
anything else to look out for?
much thanks & aloha
island cruiser is offline   Reply With Quote
Old 05-17-2006, 09:44 PM   #2 (permalink)
View tashirosgt's Photo Gallery
I think your car is the same as a 96 prizm. The service manual for the '96 prizm includes the following steps in removing the timing belt:
13. Loosen the idler pulley mounting bolt
14. Loosen the idler pulley adjusting bolt and remove the A/C compressor drive belt.
15. (remove) A/C electrical connector
16. (remove) Four bolts and and A/C compressor, relocate compressor and suspend
The "idler pulley mounting bolt" is the bolt through the pulley and the "idler pulley adjusting bolt" is the one through the top of the bracket whose head faces the hood.
tashirosgt is offline   Reply With Quote
Old 05-23-2006, 02:37 PM   #3 (permalink)
thanks for the info.
i ended up pulling the alt up out of the way and it gave me enough room to get to that cover bolt. alt came out quick & easy, i didn't have to fuss w/compressor at all.
93 Corolla - 1.6L, surf racks, lots of dents
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 02:13 PM
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
Camry 2000 Timing Belt and weeping water pump joanobie 3rd & 4th Generation (1992–1996 & 1997–2001) 10 08-17-2005 02:04 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
Bad Water pump or not?? Ghost Archived Corolla threads 3 07-04-2004 08:46 PM
