Starting problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2006, 04:24 PM   #1 (permalink)
AMS
View AMS's Photo Gallery
AE92 Starting problems
My 89 AE92 stalled one day. I replaced alot of stuff and it now try to start but wont keep running. Anyone have any ideas? thanks!
AMS is offline   Reply With Quote
Old 05-17-2006, 06:10 PM   #2 (permalink)
View PeonHonda's Photo Gallery
how long does it run for when you start it. it could be a bad crank sensor.
PeonHonda is offline   Reply With Quote
Old 05-17-2006, 07:42 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
our ae92's have crank sensors?
I thought those were for electronic ignitions, so the ecu knows when to fire what using the coil pack...
I would say check the starter wire but if your gettin somethin then I doubt that would be it. all I can say it check the fuel pressure, if it's an 89 and it's an sr5 or sedean maybe the carb has bit the dust?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-18-2006, 02:38 AM   #4 (permalink)
AMS
AE92
It runs for like a second or two and then stop it putts like its about to start like if the timing was wrong but its not I checked the timing on the cams and at the distributor. Or like if it doesnt have enoungh spark or fuel but it has both I replaced the Fuel pump,o rings on the injectors, it has plenty of pressure now I replaced the ignitor,Ignition coil,wires, plugs. This is driving me crazy but its kinda fun cuz I have no idea what it is and when I find out thats going to be really cool! Thanks for your help guys!
Old 05-18-2006, 04:29 AM   #5 (permalink)
Vroom?
freakinbox's Avatar
just because you replaced the pump doesn't mean all the lines are good, or that the injectors aren't finished.
the engine need 3 things to run. Fuel, air, spark. usually it's one of those 3 that cause your issues. Have you actually checked for a spark or just replaced parts?
Old 05-18-2006, 12:24 PM   #6 (permalink)
AMS
Yeah I checked for spark I put a screwdriver in the wires put it against the block and I seen the spark I did the same thing with the spark plugs against metal. I did a fuel pressure check and it went up alot after I replaced the fuel pump. Thanks again for your help. Any more Ideas??? I just really wanna fix this car.
Old 05-18-2006, 02:35 PM   #7 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
wah is this safe to do?
Ceck plugs, wires, air filter, is the battery good, battery cables clean, fuel filter
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 05-18-2006, 02:45 PM   #8 (permalink)
AMS
No its not really safe to do but its one of the many test us back yard mechanics do. Yeah fuel filter is new air filter is new. I have spark everything. I am looking for some kind of sensor maybe. Maybe it is my ecu that is making it not run but if it was my ECU I dont even think it would try to start. Thanks again guys
Old 05-18-2006, 02:51 PM   #9 (permalink)
View tashirosgt's Photo Gallery
Is the timing belt on tight? Could it have slipped a tooth?
You said you replaced many things. How far did you go in taking the engine apart? Did you do a compression test?
tashirosgt is offline   Reply With Quote
Old 05-18-2006, 02:58 PM   #10 (permalink)
AMS
Yeah I have compression on all cylinders #1 was kinda low so I put some oil in it and it and it went up therefore its the rings but I dont think that would keep it from firing up. It didnt slip a tooth either I checked the timing on the cams and at the distributor. any other thoughts? Hey does anyone know where I can get aftermaket fuel Injectors I am going to replace those and see if that does it.
Old 05-19-2006, 01:09 AM   #11 (permalink)
The terrorist
View Xenon's Photo Gallery
I had a similar problem with my Civic.. But it was the map sensor hose that got disconnected by accident while I was working in the engine bay
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 05-19-2006, 09:51 AM   #12 (permalink)
Koo'rolla Lives Forever
New'rolla's Avatar
View New'rolla's Photo Gallery
well here's my starting problem too then. i have a 1991 Corolla GTS, with the red-top 4age, and i was running the car the other day, and i jumped in and revved it up (stupid but it was at like 6000) and it just died, and never started again, the car turns over but wont even kick, the fuel pump wire had no power goin to it, so i re-ran the fuel pump wire, but now it wont even kick, and i know there is fuel, and air, and spark was good, any idea what could have blown to make the car shut down?
the cams are all working so i never fucked the internals, it's just something electrical (i think) any ideas? give me ever idea and i can just try them all out and see what i get.
New'rolla is offline   Reply With Quote
Old 05-19-2006, 02:47 PM   #13 (permalink)
AMS
Are you sure you still have all those?
Old 05-19-2006, 07:08 PM   #14 (permalink)
New'rolla's Avatar
what do you mean??? ^^^^^^^^^^^^
would that box after the air filter stop the engine from running? i heard if the door wasn't open the engine wont start... but how does it even open? doesn't it open with pressure?
Old 05-19-2006, 08:18 PM   #15 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
could be the igniter
Problems starting 94 toyota tercel Gordon Tercel, Paseo, Starlet, and Sera Forum 27 08-26-2006 11:58 AM
starting problems tacoma-05 2nd Generation (2005+) 68 04-28-2006 04:42 PM
1991 Corolla has Occassional Problems Starting PoopEater Archived Corolla threads 5 01-08-2006 06:22 PM
Tercel 94 Starting problems alxv Tercel, Paseo, Starlet, and Sera Forum 1 10-05-2005 01:43 PM
starting problems mr2trbo93 MR2 Forum 9 06-12-2005 11:26 PM
