Torque Peak - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 05-18-2006, 03:12 PM   #1 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
USA Torque Peak
Just looking to see if someone can clarify something for me....
I have found two different infos on torque peak for the 05 rolla s 1.8 VVT-i
First I found by googling that it is 2880 RPM
Then I went to http://www.edmunds.com/new/2006/toyo...065/specs.html and according to them the torque peak is 4200 RPM.... Does anyone know the real spec on this...
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline
Old 05-18-2006, 03:35 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
4200 sounds closer to the truth.
Flashmn is offline
Old 05-18-2006, 04:43 PM   #3 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
4200 RPM is correct
Chris Corolla S is offline
Old 05-18-2006, 06:06 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
maybe it's both
maybe one is going by the use of vvt-i that would technically give it to different torque peaks...
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline
Old 05-18-2006, 10:58 PM   #5 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
Well I know it has good torque between 2-4K rpm, good HP 4-6K rpm (gotta love vvti) But as far as I know the peak torque is around 4500 and max hp around 5500
Toyota 4 life!!
ToyotaMan1281 is offline
Old 05-19-2006, 07:41 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
well a car cant have two peak torque points. and no a 1.8 liter engine WONT have its peak torque at V8 rpm readings.
Flashmn is offline
Old 05-19-2006, 10:53 AM   #7 (permalink)
Vroom?
freakinbox's Avatar
well it technically can. If they go by the torque peak for the 2 sets of lobes. the change in timing would change the torque peak... thats what makes vvt and vvt-i so great
Old 05-19-2006, 11:12 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Umm no, because the torque curve cant be like that.
Thats not the main idea of vvt to begin with. its there to produce a much broader torque curve, not to give peak torque down low and again at high rpm. its impossible.
Flashmn is offline
Old 05-19-2006, 02:27 PM   #9 (permalink)
View Guido's Photo Gallery
If Toyota could make cam #2 peak at the same place as #1, yet with a flatter/broader curve, then they wouldn't need cam #1 because it wouldn't offer any advantages. If it peaks at a different point than cam #2... then you have two peaks on the same engine.
Guido is offline
Old 05-19-2006, 03:35 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
what cam 1 and cam 2? There is no cam one and cam two, theres only one cam. Toyotas vvt doesnt work like Vtec where there's another lobe, but even then theres only one peak torque point in the engine and thats in the Vtec lobe.
Flashmn is offline
Old 05-19-2006, 03:41 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
Since you guys are a bit out in the woods, heres a pic to clear it, its from a 2ZZ-GE.
Notice the torque band? The peak torque is where the highest reading takes place, nowhere else, now you cant have peak torque down low and high up. Notice how peak torque in this build is at 5800rpm, just before it falls off torqueband. Claiming otherwise is just ignorance in how an engine works.
Flashmn is offline
Old 05-19-2006, 04:35 PM   #12 (permalink)
Originally Posted by Flashmn
Toyotas vvt doesnt work like Vtec where there's another lobe...
"The VVL portion of the system is similar to Honda's VTEC system, incorporating two distinct cam profiles".
http://www.corollaperformance.com/TechInfo/VVTLi.html
The photo clearly shows 2 sets of lobes. Each lobe has it's own peak.
Toyota chose to blend the peaks together so one occurs after the other. But they are still there. If they wanted to, they could have one cam (or set of lobes) peak at 3000rpm @ 100HP, and the other cam peak at 5000rpm @ 100HP. You'll have 2 peaks on the same engine. Doing it with a single cam is impossible. Have 3 cams and you can have 3 peaks, etc.
Guido is offline
Old 05-19-2006, 05:00 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Yeah maybe so, but still the engine has only ONE peak torque point. Try and understand it.
Flashmn is offline
Old 05-19-2006, 05:25 PM   #14 (permalink)
Understand that technically it can have two (or more) - as freakinbox said, which you denied. It's not rocket science.
Guido is offline
Old 05-19-2006, 05:50 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
Hey whatever.
This is pretty much beating a deadhorse
Flashmn is offline
Closed Thread
Mystery Rolla wiccanferret Archived Corolla threads 20 04-07-2005 01:22 AM
Best catbacks? CrawlingEye Camry & Solara Lounge 58 04-23-2004 09:45 PM
How to apply 200 ft lb torque w/ 150 ft lb max torq wrench? Corbett Archived Corolla threads 11 09-26-2002 04:07 PM
is there a supercharger available for 180hp engine? Sub Zero Celica Forum 13 03-03-2002 08:03 AM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 09:54 AM
