C56 vs C160 Mounts/Length - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2006, 01:26 PM   #1 (permalink)
View richard_rsp's Photo Gallery
Ok, so I am trying to find out if the C160 6-speed and the C56 5-Speed use the same tranny mounts...
I'm pretty sure that they are the same mounting points on the car itself (duh, since you can swap either in) but do they have the same mounting points on the tranny case?
Also, does anyone know the length difference between the C-56 and C-160?
Any help would be great!
richard_rsp is offline   Reply With Quote
Old 05-19-2006, 02:41 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
As far as I know the mounts are the same.. its the shift linkage that differs.
Old 05-19-2006, 09:15 PM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
I can tell you as soon as i import one from New Zealand...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 05-19-2006, 11:24 PM   #4 (permalink)
View 94_Rolla_Guy's Photo Gallery
typically i think the box will be about 2-3 inches longer...
Are you trying to put a 2ZZ gearbox on a A series engine? because the C56 is a 4age 20v tranny and if i remember correctly the C160 is the 2ZZ gearbox?
the bell housing will not fit...........i have held a A series block plate to a 2ZZ gear box (c160??) and theres no way!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 05-20-2006, 12:38 AM   #5 (permalink)
View epyon22's Photo Gallery
ive heard theres a way to do the zz trans to a a series i cant remember where search the forums i think they are on this site ren do you remember what im talking about?
'89 ae92 GT-S bought brand new dec '88
http://photobucket.com/albums/v227/epyon22/car/
epyon22 is offline   Reply With Quote
Old 05-20-2006, 01:05 AM   #6 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
If the 6 speed is out of a levin or simular it will fit and the sharfts sould be the same..as long as you have a 4age box already...as far as mounts go they should also be the same!
if not just give a local import export company and they will give you the right ones but its not a matter of will it fit but yes it will with the right mounts....as large manufacterors hate to make new stuff i think you'll be right if its the same body type!
what is your shell and running gear spec eg ae95,101,111, etc, and motor 4age or 4afe, etc
what box you got now?.....
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 05-21-2006, 01:29 AM   #7 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
The c160 is out of the ae111 with blacktop they had 6 speed as an option lsd was optional, on the 2zz the 6 speed is the c60 which has the same gear ratios but has some difference maybe its just the bell housing? Who knows?
canadianae92 is offline   Reply With Quote
Old 05-21-2006, 02:52 AM   #8 (permalink)
cuzman's Avatar
what are you putting it into? if its an ae92 or simular....?
if its a later model shell it will surly fit with an apropiate box mount from toy...
Old 05-27-2006, 06:52 PM   #9 (permalink)
Sorry for the long wait for reply, been away from the net...
I am looking at swapping a c-56 on to the 1NZFE in an Echo. I know (from Wraith on this forum and echodrivers) that the C160 mounts up to the stock locations (it does require a bell housing swap) but is slightly too long and requires a frame cut. I am looking into swapping the C56 so I can get A) a more 'performance oriented' final drive and B) have an 8-bolt final drive that can accept an LSD. (echo stock is a 6-bolt).
I was asking on the corolla forums cause I figured you guys would know!
Thank you to everyone!
Old 05-27-2006, 11:53 PM   #10 (permalink)
cuzman's Avatar
sorry dont know about the echo motor! but will have a look for ya!
sounds like a good swap...i'll be back with info soon..
Old 05-28-2006, 11:01 AM   #11 (permalink)
KDM is in
REN69's Avatar
If Wraith said you have to cut the frame.. I'd believe him, he was trying to do this swap for a while I think.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-28-2006, 05:47 PM   #12 (permalink)
The TN Member
View punter's Photo Gallery
The gearbox mount on the c160 is slightly different. The c5* one will work just needs a few holes slotted out. Apart from that everything is the same, driveshafts etc. are interchangable.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 05-28-2006, 07:46 PM   #13 (permalink)
hmmm...
Yeah I have seen pics of wraith's cuts in the frame for the c160. I am hoping that the C56 will be shorter than the C160 so it will hopefully clear the frame.
Well thats good news about the mounts! I hope that this will work! I will do a write-up when it happens (I have to wait until my car can be down in September., just doing some preliminary homework)
Thank you everyone!
C56 final drive 94_Rolla_Guy Archived Corolla threads 6 11-16-2005 01:46 PM
C56 Trans vs C52 EProd23 Archived Corolla threads 6 01-25-2005 03:41 PM
