Vibrating in 2003 Corolla - Is this normal? Please help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2006, 03:24 AM   #1 (permalink)
View JayHM's Photo Gallery
Hi all. I'm new here. I recently bought a 2003 LE in excellent condition with only 16,000 miles. Unfortunately, I've been less than pleased with it, mainly due to an excessive amount of vibrating and rattling.
The car in general vibrates a lot when idling under 1000 rpm. The steering wheel vibrates, the dash vibrates, the driver's seat vibrates, the gas pedal vibrates... it's enough to drive one batty in stop-and-go traffic. It's NOT an outrageous amount of vibrating, but definitely more than I would expect from a 2003 Toyota with low miles.
In addition to vibrating at low RPM, there are some rattles in the dash, under the glove compartment (inside the corrugated pipe that holds the ECU wire harness), and from within the passenger side door. These are actually more like vibrating buzzing sounds than mere rattles, and they can be quite annoying.
I took the car into the dealer, and he installed some foam insulation here and there. It fixed the dash noise, but none of the others. And the car itself still vibrates at low RPM.
I took it into another mechanic to check the engine and transmission mounts. They're all fine (as expected at 16K miles).
I'm at a loss. The dealer tells me this is normal. Is this true? My 97 Mitsubishi Mirage didn't vibrate like this, even after 100K miles, and that's a Mitsubishi!
Please help! Thanks!
JayHM is offline   Reply With Quote
Old 05-20-2006, 10:49 AM   #2 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
I have an 03S and outside of the engine being noisy till it warms up its a very quiet running car, sounds like you have some engine issues because excessive vibration will cause any car to start rattling in places...Start by getting an engine diagnostic check up!...good luck and keep us updated...~Radd
Raddman is offline   Reply With Quote
Old 05-20-2006, 10:51 AM   #3 (permalink)
Registered User
Raddman's Avatar
USA
I forgot....WELCOME TO THE FORUM...~Radd
Old 05-20-2006, 04:18 PM   #4 (permalink)
It's most noticable when I'm just sitting idle at a stop light. I wonder if it might be a timing / tuning issue. The vibration is very noticable at 1200 RPM, and then again at 800 RPM and below.
It's an automatic, BTW. I'll be taking it back to the dealer on Monday for the third time...
Old 05-23-2006, 02:56 AM   #5 (permalink)
Well, I took it in this morning, and the service advisor said he thought the throttle body and fuel injection needed cleaning. I told him I already had the fuel injection service two weeks ago, so he said it had to be the throttle body. I asked him how sure he was that this would fix the vibration, and he said "pretty sure".
I got a call back in the afternoon telling me that the throttle body cleaning didn't fix the vibration. He then said it was normal in a Corolla to feel the engine vibration while idling because Corollas are small cars, and that there is nothing they can do about it.
At least he didn't charge me anything. I'm gonna try one other mechanic tomorrow...
Old 05-23-2006, 01:41 PM   #6 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
I have a 2006 corolla le and mine is very quiet, little noise at high revs but this is normal, little noise on highway but again this is normal with every car
this is the first model yr change they did in a while with rollas and your bound to have a few problems but not like this.
I say get some more foam in their and pop the hood with car running- is their anhthing loose in the engine? Anythiung a little loose inside (radio, controls, etc).
start with this and let me know how u made out.
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 05-23-2006, 02:51 PM   #7 (permalink)
View Ghost's Photo Gallery
I have heard some where, I think even on this forum.....that the 2003 models, at least some had a problem or defective engine mount that went bad, I can't remember whether it was the passenger or drive mount, but it was one of them...and what people did to solve the problem was just simply replace the mount...their cars also had low miles
hope that helps....
Ghost is offline   Reply With Quote
All 2003 Corolla - Low Washer Light JakeJacobs 9th Generation (2003-2008) 22 10-11-2007 09:09 AM
questions about 2003 corolla S sick-boi Archived Corolla threads 9 04-04-2005 06:27 PM
2002 Corolla tape deck in 2003 Echo louise Audio, Video, and Security - Tech 1 08-04-2004 11:07 PM
2003 corolla engine rattle qmpsdpz Archived Corolla threads 1 03-01-2004 05:28 PM
Any Thoughs Corolla S 2003 amaurym General Discussion 6 10-09-2002 10:23 PM
