Mega squirt question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2006, 10:09 AM   #1 (permalink)
View Blazin674's Photo Gallery
Question Mega squirt question
the question is when i instal a mega squirt ecu do i still need my factory harness to run my lights and guages? i have a 94 geo prizm and im putting in a bt. sould i get the setup like on the 85 sr-5s where they have that 12v box for it? really would apreciate help thanks
Blazin674 is offline   Reply With Quote
Old 05-23-2006, 10:11 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
No, lights and accessories are run from the cars wiring harness. With ms, you'll have a separate engine wiring harness for the MS box.
Old 05-23-2006, 10:25 AM   #3 (permalink)
ok thanks
Old 05-23-2006, 10:39 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
No probs, I'm working on a MS project for my corolla.
Old 05-23-2006, 11:27 AM   #5 (permalink)
what motor are you putting in?
Old 05-23-2006, 01:01 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
4A-F converted to fuel injection.
Old 05-23-2006, 02:06 PM   #7 (permalink)
Gameroom cash: $134355
just unplug the entire engine harness..... disconnect the 'molex' as well.. but don't cut that up.... you can then start hacking the stock harness up so that it's easy to wire into MS and you don't end up with more than you need for MS
this is a bit brief and was written at 3am... but:
http://northwestmr2.com/viewtopic.php?t=263
Old 05-23-2006, 03:07 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
well MS doesnt know too well how to read the stock sensors. I added bosch sensors to my engine, not too hard to do.
Old 05-23-2006, 04:50 PM   #9 (permalink)
are the pins on the ae 92 ecu the same as an ae102 ecu
Old 05-23-2006, 04:52 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Dunno, I never had an ECU to start with.
Old 05-23-2006, 10:47 PM   #11 (permalink)
only problems are the clt and ait sensors.... swap out the resistors for 2.2k ohm ones and you'll be fine
Old 05-24-2006, 04:40 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
and the tps, its reverse on the GE and the fE one is the switcheable, so that wont work at all.
My tps is from a volvo V70/S70, and i opted to change the coolant and intake airtemp sensors to bosch sensors as my box has the tables for them. Installation of them was dead easy, I drilled and tapped the coolant temp sensor into the head just under the distributor. Then I put the IAT sensor into the charge pipe just before the tb. Plus as they're standard bosch sensors, finding connectors for them was dead easy.
Old 05-24-2006, 12:29 PM   #13 (permalink)
yeah, tps on a 4afe wouldn't work as it's not a potentiometer..... a 4age/4agze one works fine, trust me
if it's reversed then all you need to do is switch 2 wires
Old 05-24-2006, 01:25 PM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, but a GE Tps wont fit the TB of a 4A-FE, the GE one is with the toyotas weird claw and the FE one is with the 8mm D axle. Volvo S70 TPS fit just fine with little modification.
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
mega squirt fuel injection controllers subliminaltrips 89-95 Toyota Pickup/Hilux 5 11-19-2005 12:43 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
Mega Squirt UK_MRV6 Camry & Solara Lounge 2 01-07-2005 05:38 PM
