CD Skips with A/C on. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2006, 04:23 PM   #1 (permalink)
View GuJu MaN 89's Photo Gallery
i have 97 rolla, and when i turn the a/c on, after like 30 minutes the cd starts skipping around and the cd is realllllllly cold when i take it out and one time it had water on it, any suggestions?
GuJu MaN 89 is offline   Reply With Quote
Old 05-23-2006, 04:53 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
The AC lines go thru behind the where the radio is, and also there are vents going over the radio. Could be maybe condensation building up either on the vents or the AC lines and its dripping on the radio. Try not cranking the AC or maybe turning it on/off every 10mins or so. If that doesn't work you could have a problem with the lines.
Old 05-23-2006, 05:30 PM   #3 (permalink)
yea i think its the codensation, any1 way to stop it? like put something there like a sealent.
Old 05-23-2006, 07:17 PM   #4 (permalink)
KDM is in
REN69's Avatar
maybe there's a hole in the vents, might be helpful to take that area appart and see what's causing it.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-25-2006, 01:19 AM   #5 (permalink)
View Limnos's Photo Gallery
It strikes me that what's as likely is that you are getting condensation directly onto the CD from the air because the CD is cold from being affected by proximity to the car's ventilation system. I'd think the moisture in the air would mostly condense in the AC system right where the cooling takes place near the condensor, not along the line unless you have warm, moist air being mixed with the stuff in the line. Even if it is leaking from the line you may still have an issue with direct condensation onto your CDs if they are being cooled by being right next to the ventilation system. You could also run the risk of posssible damage to your CDs when you use the heating in your car if they get too hot. I know that in my girlfriend's old Chevy Nova (Corolla in disguise), her tapes would reflect the temperature settings.
If you can spot a direct leak onto the CDs from the air ducts then that may solve your immediate problem. You could also make sure that when you have your AC on that you use the recirculation rather than fresh air setting. That way the air will get dried out more thoroughly. Otherwise you may need to find some way to put insulation around your sound system so it isn't affected so much by the ventilation in your car. You could also see if the ductwork is tight and maybe seal up joints so you don't get leaks along the line that may be blowing into your sound system and causing temperature extremes.
1981 Corolla Wagon, 5-speed, 159k miles-- my winter wheels
1981 Corolla Wagon, AT, 125k miles-- my summer wheels
** I replaced a horn. Isn't that mod. enough? **
Limnos is offline   Reply With Quote
CD player skips and cuts out at certain RPM's? Celica4life Celica Forum 7 04-06-2005 01:45 AM
cd skips from bass spydrvnm Audio, Video, and Security - Tech 11 08-24-2004 07:35 PM
Factory CD player skips BigPete Audio, Video, and Security - Tech 0 08-06-2003 07:20 PM
