Cold start problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2003, 02:50 PM   #1 (permalink)
View vpn2001's Photo Gallery
Cold start problems
My 1994 Corolla has a problem starting in the morning. But once it starts, it runs and restarts without problems. I have already replaced the idle valve, temperature sensor, spark plugs, fuel filter, air filter, distributor cap, and distributor rotor. Any help is appreciated.
vpn2001 is offline   Reply With Quote
Old 02-26-2003, 03:21 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
its prolly ur battery.....how old is it??..when was it last replaced??...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-26-2003, 03:28 PM   #3 (permalink)
Forgot to mention...new battery.
Old 02-26-2003, 04:09 PM   #4 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Here are some thoughts ...
Is your timing too advanced?
Consider synthetic oil.
Ohm check the temperature sensor and make sure it is working properly. If you have a temperature gauge just have a good look at it to make sure the reading makes sense.
Plug it in.
Don't light a fire under it to warm it up :p
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 02-26-2003, 10:52 PM   #5 (permalink)
View Nx2k's Photo Gallery
is it throwing a code?
igniter problem possibly
signature suspended. Please read the rules. No animations.
Nx2k is offline   Reply With Quote
Old 02-26-2003, 11:32 PM   #6 (permalink)
aka TRD_roLLa on CC.com
View ractive_roLLa's Photo Gallery
93-97 corollas usually has problems w/ their starters.. my dad brought it to toyota a few years back and fixed something.. it wasnt the whole starter though.. i forgot what it was..
and my friend right now has a 95.. and its NOT starting.. but they're getting it fixed as we speak..
BTW i have a 94 also.
ractive_roLLa is offline   Reply With Quote
Old 10-20-2005, 03:55 PM   #7 (permalink)
Grubby Stanks
View ProNeutronical's Photo Gallery
Exclamation Also cold Start problems Here
I also have trouble with my 1995 Corolla cold starting. Once it starts, no problems all day. No check engine light on, except for when I put key into ignition and start. Car turns over, no start. My neighborhood mechanic, not a Toyota dealership shop, thinks it is a signal not being received by the crank shaft. One local dealer suggested over the phone that it might be the cold start ignighter. Does the 95 Corolla even have one? The earliest I can get my car to a dealership shop is Monday, 10-24-05. I just want to have an understanding of what I am up against here. Any suggestions?
ProNeutronical is offline   Reply With Quote
Old 01-08-2006, 07:33 PM   #8 (permalink)
View jakro1972's Photo Gallery
cold start
does it crank yet wont' start, meaning it turns over with the starter? If so, do you have a cold start injector? My 92 had one. It operates off a thermo-time switch that goes into the coolant. All I had to do was remove the cold start injector and clean it with carb cleaner and it's worked fine since!
jakro1972 is offline   Reply With Quote
Old 01-08-2006, 08:44 PM   #9 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
mine started like it was 20 degrees outside tonight and it was 55 degrees, I think its just something that happens now and then... <--- 2006 LE
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 01-08-2006, 08:46 PM   #10 (permalink)
Gameroom cash: $134355
check your CSI (which is the black injector mounted in the middle of your manifold..... it has a small metal fuel line that runs from the rail ti it.... if need be, use 2 small wires, run a positive to one prong and touch a negative to the other.... do this with the car NOT running... you should hear the CSI click... if not, it's not working properly). Also, check to make sure the GREEN coolant temp sensor is hooked up and functioning properly... it is tied into the the cold start injector (it's the cold start timer). If it isn't reading correctly, then it won't turn the CSI, and you won't have the added fuel at startup. (the cold start sequence is very similar to a choke setup on a carb)
Old 01-09-2006, 11:08 AM   #11 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Usually its the starter solenoid contacts in the starter that wear out. They are easy and cheap to replace.
The way you can tell if this is the problem is if you just hear a click when the car doesnt start.
If it actually cranks and doesnt start it's something else.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
