Differential fluid change on a '99 auto? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2006, 07:19 AM   #1 (permalink)
View shampooguy's Photo Gallery
Has anyone ever changed the differential fluid in a '98-'01 auto? On my '93 there is a seperate differential drain plug (other than the tranny plug), and my Haynes manual says there is one for the '99, but it's nowhere to be found. Thanks
shampooguy is offline   Reply With Quote
Old 05-25-2006, 08:50 AM   #2 (permalink)
View Guido's Photo Gallery
Never changed it.
Why are you changing it?
My 92 Lincoln manual says never check or change the diff fluid. Only time to replace is if repairs were made, otherwise just leave it alone as it came from the factory. Check your manual, it MAY say the same thing. Just trying to save you some work.
Guido is offline   Reply With Quote
Old 05-26-2006, 08:27 AM   #3 (permalink)
Differential failure will very quickly lead to transmission failure...just trying to maintain my drivetrain.
Old 05-26-2006, 12:41 PM   #4 (permalink)
OK good luck.
Oh and that's why I hate Haynes - they're way too generic for any real work.
Old 05-26-2006, 11:03 PM   #5 (permalink)
View tashirosgt's Photo Gallery
In the Toyota Service Manual for the 1998, it shows no separate drain and fill for the manual transmission.
For the A131L automatic transmission the manual shows a drain plug and a fill plug. I don't have access to a 1998 Corolla, but the diagram seems to be from the viewpoint of someone under the car and looking at the back of the differential. There is a circular motor mount and to the left of it a rectangular object (another mount?). The fill plug is slightly behind the rectangular object, but roughly between the rectangular object and the circular motor mount as you look at this view. Its head faces the back of the car. The drain plug would be on the bottom of the left bottom corner of the transmission in this view. Its head faces the ground.
No separate diagram of this is given for the A245E automatic transmission.
tashirosgt is offline   Reply With Quote
Scrapyard in the GTA TdotTercel General Discussion 16 11-23-2011 03:18 PM
2000 Camry Auto trans fluid WEFs00 3rd & 4th Generation (1992–1996 & 1997–2001) 15 01-28-2007 09:25 PM
when to change trans. fluid chrisusvi Tercel, Paseo, Starlet, and Sera Forum 3 03-07-2006 05:14 PM
power steering fluid change gen3 OMNI 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-11-2006 05:46 PM
auto tranny fluid change on a 92 sedan jjminch Archived Corolla threads 3 01-06-2006 03:59 AM
