stroking the 4a block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2006, 11:35 AM   #1 (permalink)
Grip>Drift NA>blown
View ae102geo's Photo Gallery
I know the bores are the same on the 4age and 7afe so what were to happen if I put a 7afe crank and rods in a 4age block? besides the 200cc difference
ae102geo is offline   Reply With Quote
Old 05-26-2006, 11:54 AM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
the pistons would come about 15mm out the top of the bores! if you want the stroker 7A advantage get a whole 7A bottom end and do a 7A-GE hybrid...
search "7A-GE" here and google you will find quite a bit of info!
the only other thing you can do is to try and find a HKS 5A-GE kit that makes 1.8L on a 4A-GE block! but... hard to find and rather expensive!
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 05-26-2006, 01:11 PM   #3 (permalink)
Grip>Drift NA>blown
ok all of that looks good except for one thing. everyone says the 7a bottom end is week. i noticed that the 2zzge engine revs to nearly 8,000 and can go past, and the stroke is the same length. could the 2zzge crankshaft, rods pistins be swapped into a 7a block. The bore doesn't matter I will get the blocked honed and bored if need be.
Old 05-26-2006, 01:54 PM   #4 (permalink)
Gameroom cash: $134355
no... not all is good.... the 7a has a longer stroke, yes... but it also has a taller block.
more than likely you'll smash the pistons into the head
Old 05-26-2006, 02:42 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Where did you hear the 7A bottom end was weak? The whole reason to build a 7AGE hybrid was that the 7AFE had a stronger bottom end than the 4AGE, the 7AFE bottom end would be able to put out more torque IMO.
Like rolla_guy said.. search for 7AGE, Rolla pat from Montreal has done this conversion on his AE86 and its putting out some decent power.
Old 05-26-2006, 02:54 PM   #6 (permalink)
Grip>Drift NA>blown
"With longer crank stroke, the 7A-GE’s cannot be revved as far due to known failures of connecting rods and bearings. The maximum power band usually falls at as little as 6800rpm, a sign of internal stress, meaning it’s way-past the physical redline… Most tuners recommend its use below 7500rpm"
http://www.club4ag.com/faq%20and%20t...20and%207A.htm
Old 05-26-2006, 04:40 PM   #7 (permalink)
yeah, ren... the 7a's crank is actually weaker than any 4age.... all of the 4age cranks are forged, wereas the 4afe/7afe's aren't
i wouldn't be surprised if toyota used the smaller journals on the 7a crank much like the 4afe cranks got....
Old 05-26-2006, 05:38 PM   #8 (permalink)
Grip>Drift NA>blown
http://www.billzilla.org/starleteng.htm
what do you guys think about the first two engine and the one at the bottem in the buggy
Old 05-29-2006, 04:04 AM   #9 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
For all the stuffing around get a 4agze...cheap and easy and has even more torqe
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
junction block jahwish10 Previa Forum 0 04-30-2006 06:48 AM
5s block with 3S head and accessories EnvyMyDrifts Celica Forum 4 09-18-2005 09:22 PM
4a fe head on 4age block fleetwood dicki Hardcore Tech and Competition 3 02-15-2005 12:03 PM
4AGZE Block code ? Red_85_AE86 Archived Corolla threads 3 02-12-2005 12:10 AM
'96 GT Block Drain Plug GT '96 Celica Forum 1 07-13-2004 05:44 PM
