Crank Pulley Wobble
I have a '94 Toyota Corolla 1.8L 7A-FE. I just replaced the timing belt, water pump, acc. belts, plugs, etc. The water pump bearing on the pulley end had gone bad and their was a serious whirring noise along with squealing belts. So I finished the job tonight and I noticed the crank pulley was wobbling at idle. The wobble seems to disappear when your raise the RPM's but I could be wrong. The car has about 200K on it and if the wobble won't adversely affect anything I will leave it alone but if it is going to cause issues then I need to fix it. Maybe it was partially the cause of the bearing going bad on the water pump. Any help would be appreciated.
