The Swap Has Begun! - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2006, 05:07 PM   #31 (permalink)
AMS
View AMS's Photo Gallery
I agree the CRX is an amazing car one of my favs! And the handling is sooo good I have Neuspeed Race Springs with Bilstien Shocks rear disc brake conversion from a 92 Integra front and rear upgraded sway bars upper and lower strut bars and the steering response is one touch and it goes wherever I put it so you are very right the CRX does handle better I was just very surprized how well the AE92 handled. And I thought the engine was close to the B16 but you say its not and the 20v is so when I do my swap I will be VERy pleased. And as for drifting in a FWD you can do a power over technique weight shift kinda thing where you don't use the E brake. If you go into a turn on the far side very fast and then turn in as hard as you can to the inside of the turn and gas it your rear wheels will brake loose and then counter steer and tap the brakes if you want to slide more or gas it to control the slide to come out of the slide bring your wheels to a straight and gas it. It not as easy as I put it. You have to be able to feather the clutch and have throttle control. I have drove a RWD I still preffer FWD I went to a few canyon runs in the RWD 240 SX there is just to much oversteer I mean you have to make sure you just turn the wheel a lil bit in a FWD you have understeer which I can work with.
AMS is offline   Reply With Quote
Old 06-02-2006, 07:10 PM   #32 (permalink)
Gameroom cash: $134355
..... drive an mr2..... it's FWD in the back of the car..... better handling than FWD and not as much oversteer as a FR
Old 06-02-2006, 07:11 PM   #33 (permalink)
Originally Posted by Flashmn
Locks the rear wheels up very easily. Its a handbrake that uses an additional master cyl, where the original brakeline routs through, it works normally when the handle isnt pulled, but when you pull the handle, it pressurizes the rear brakes.
I'm surprised you've not heard of a hydraulic handbrake.
uhh.... looks more like a clutch slave cylinder bolted onto a bunch of machined metal!
Old 06-02-2006, 09:26 PM   #34 (permalink)
AMS
Yeah I could imagine driving an MR2 that would be crazy where the weight of the car is it would be a diffrent driving experiance
Old 06-03-2006, 06:33 AM   #35 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Trust me... I own both an AE92 and an MR2 (with a 20v no less)... there is NO comparison. None!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 06-03-2006, 05:26 PM   #36 (permalink)
View lifeisviewtiful's Photo Gallery
Originally Posted by REN69
4AGE swaps are like women.. if you like making your girl scream, then go with a 20V swap. If your girl likes it fast and hard, then GZE is your swap.
If you like to make your girl scream fast and hard.. 3SGTE FTW.
thank you for my new sig ren.......you are going on my christmas list.
lifeisviewtiful is offline   Reply With Quote
Old 06-03-2006, 05:46 PM   #37 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Ever heard, that you can do it DIY? all you really need is the master cyl of the clutch or the brake.
And as for the CRX being so great and all mighty, we dynoed a CRX with a ZC engine, wanna guess what the power output was... 61hp So much for being great.
Oh an FWD can do "the powerover technique"? That I'd like to see.
4age 20v vs b18 swap good_old_geo Archived Corolla threads 15 08-28-2006 07:37 PM
20V Swap, can someone help? -HiTMaN- Archived Corolla threads 8 02-24-2006 05:02 PM
3EE to 5EFE engine swap DaBomb77 Tercel, Paseo, Starlet, and Sera Forum 2 08-20-2005 10:51 AM
1992 Toyota MR2 Swap eMcEeNeSs MR2 Forum 7 07-26-2004 10:20 AM
ATTN: speedemn - Yoshio Engine Swap Ratko Camry & Solara Lounge 4 12-28-2001 04:22 PM
