Brake lights stay on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2006, 12:33 AM   #1 (permalink)
View ntxjoe's Photo Gallery
My daughters Corolla :rolleyes: 93, the brake lights stay on. Threrfore it drains the battery. I have checked for resets and can't find any. Where do I start to look to resolve the problem?
ntxjoe is offline   Reply With Quote
Old 05-31-2006, 12:53 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
I'd say the switch on the pedal will be worn or loose, some are adjustable. Should be an easy fix
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 05-31-2006, 01:11 AM   #3 (permalink)
<3 lift
View XRS yo's Photo Gallery
Either that, or rotted wiring has metal touching other metal and something is shorted out. Wiring issues are usually a pain in the ass... But definitely check the switch on the brake pedal first.
2005 Toyota Corolla XRS / GainesvilleRacing.com
XRS yo is offline   Reply With Quote
Old 06-01-2006, 02:02 PM   #4 (permalink)
View cam76034's Photo Gallery
This happened on my daughter's 90 corolla. Like punter said, you need to take a look at the switch. In my case, nothing was wrong with the switch itself, but there is a small plastic spacer/bushing which pushes the plunger part of the switch in whenever you let your foot off the pedal. I probably would have replaced the entire switch if I had not found the pieces of it on the floor. Instead, I used a little JB Weld and glued it back into place. Good as new!
cam76034 is offline   Reply With Quote
Old 06-01-2006, 02:44 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I put a rivet in the place of that plastic thing that fell out.
89 Camry brake lights caperail 1st & 2nd Generation (1983–1986 & 1987-1991) 11 12-20-2008 10:25 AM
abs and brake lights myylwlab 1st Generation (1995.5–2004) 4 01-12-2006 07:23 PM
SR5 Brake Lights Not Working OwnerOfReality Archived Corolla threads 4 12-29-2005 12:38 PM
Driver side brake lights not working! coolchu001 Camry & Solara Lounge 3 12-04-2004 03:43 PM
All brake lights don't come on... oibone781 Camry & Solara Lounge 20 02-09-2004 12:20 PM
