maintenance required light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2006, 01:08 PM   #1 (permalink)
View dubblheelix's Photo Gallery
I have a 2005 Corolla LE. The last time the maintenance light came on the dude at the dealership said it just needed an oil change and did a little trick where he turned the key to 'on' while holding down the trip meter button. Tried that, didn't work, what am I missing here. How do I turn that light off.
Secondly, does anyone know the EXACT reason that light comes on for a 2005? Is it just an oil change indicator? Or what else is that light signifiying needs maintenance other than fresh juice?
Thanks to all in advance.
1999 Corolla
dubblheelix is offline   Reply With Quote
Old 06-01-2006, 04:17 PM   #2 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
Turn key to on position (do not start car) and hold trip meter button until it goes off. simple as that!
It comes on to remind you of service due. You have a service guide in the back of your owners manual that tells you service due every 5K miles. When the light comes on look in your book and whatever milage you have follow the maint. schedule. The maint req light will blink for 500 miles when u start the car reminding you service is coming up then when its time it will stay solid.
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 06-01-2006, 09:57 PM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
actually press and keep pressing the reset button while turning on the ignition and it should go to zero.
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 06-01-2006, 10:56 PM   #4 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Do you have a separate check engine light? If not it could always be a problem with the car... I'd check the codes.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 06-05-2006, 12:48 PM   #5 (permalink)
So nobody elses 2005 Corolla has a "maintenance required" light that comes on everytime it needs an oil chance or some general maintenance? Does anyone know if the Corolla shares that light with engine repair needed? I attache dmy OBDII reader and it had no codes.
I tried the suggestions above and the light remains on. ANYONE else with a suggestion? THANKS!
1999 Corolla
Old 06-05-2006, 01:30 PM   #6 (permalink)
2005ToyotaCorollaS
all corollas as far as I know have seperate main req lights and check engine lights, and I have a 2005 corolla s and all that light means is to change the oil, now if you have already here I will copy the procedure from my owners manual:
1. Turn the ignition key to "OFF" position with the odometer reading shown (ODO).
2. Turn the ignition key to the "ON" position while holding down the trip meter reset knob.
Hold down the button for at least 5 seconds. The odometer indicates "000000" and the light goes off.
This is found on p.114 of the owners manual, let me know if this helped.
D
How to shut off maintenance required light? RacerX001 1st Generation (2003-2008) 32 02-09-2012 05:31 PM
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 12:24 PM
Maintenance required light? bjdinnebier 1st Generation (2000–2006) 1 04-13-2006 11:21 AM
Maintenence required light reset on my '05 Joe B Archived Corolla threads 4 02-09-2006 11:49 AM
