1982 Corolla Brake Pressure Behaving Erratically - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2006, 07:16 PM   #1 (permalink)
View Rollaguy's Photo Gallery
Angry 1982 Corolla Brake Pressure Behaving Erratically
I just started driving a 1982 Corrolla and when I pulled it out the thing was fine, the brakes activated HARD when you only pushed about an inch down on the pedal (from starting position), but as I drove it the brake pressure suddenly dropped to the point where i had to floor the brake just to get it to come to a slight stop. There was no resistance in the brake pedal until about a half inch from the very very end of it's swing. We went and checked the brake fluid pressure at Lordco, and topped up on fluid, but the brake still didn't respond. Although it hasn't changed yet when I pump the brakes repeatedly the brakes rebuild pressure to about halfway through the swing and they respond nicely, but still not enough.
ANther problem is the steering is off and I think the solution to the problem above is my frnt right brake isn't disengaging properly because I recently started hearring a slight scraping noise and that wheel well heats up rapidly and the rotor's been severely scored.
Any ideas on how to get my brake to disengage again or what is wrong with my braking system?
Rollaguy is offline   Reply With Quote
Old 06-01-2006, 08:45 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Bleed the brakes! check for any damaged or worn brake lines..sounds like air is getting somwere!
Check that the pads are good all round and you may need to rebuild the f/r caliper
the system may have moisture in it,so when bleeding the system flush it aswell
good luck
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-01-2006, 10:54 PM   #3 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
^ What he said and....
...most likely its time for a new brake master cylinder.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 10:38 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
Brake fluid for 93-97 Corolla Jaspher Archived Corolla threads 4 07-26-2003 11:07 PM
97 corolla brake lights bgrieger Archived Corolla threads 1 06-27-2003 01:51 AM
