Drive Train (Help)
I've been seaching every were to find my gear box and diff types diff type with no luck!
the code is this gearbox e57-f5-834
i figured the e57 is the box,
all the codes i can hunt down say that toyota diff codes are 4 digits eg f583 etc
now if my f is the diff and pinion size far enough but i still have four digets left????
from what i know the last diget is the number of pinions and if it has lsd or not!
1 two pin
2 two pin lsd
3 four pin
4 four pin lsd
Is this right?
can some one post a code of a fwd rwd and alltrax rolla for my comparison please
as mine is awd that might be the extra diget for the centre diff or somthing?
my code is correct!
i am aware of c boxes and e boxes..but yes an e57 is unusual as i know a 4agze mr2 has a e58!
can you please state the car type and engine specs with the codes
eg 4age fwd/rwd year body type..eg coupe,hatch,wagon,all trax,sedan
this info i know is a pain as you have to grab a pen and paper but would be very usful as im makeing a code data base for all of us to share!
I will also be posting at other forums around the world to get a full data sheet of what is what and what fits including doing a brake upgrage page!
i know its every were in here but i have never seen any one talk about the hub/disk bore size or the options of using a drum handbrake (celica dics) vs direct piston handbrake (corolla) as both fit!
ANy specs again on std car is needed eg
drum/disk rear end
live diff/or no diff with stuts!
make/model..bore size..etc
abs yes/no
i asume all rollas are 4*100 pcd...
all help loved and needed ..if ive made an error some ware please pick me up!
