Inside Door Panels Squeak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2006, 10:54 PM   #1 (permalink)
View duncanmayes's Photo Gallery
When stopping, accelating and turning the door panels on the inside of car squeak.
Seems to happen when the weather is above 78 degrees.
Any ideas on how to fix problem?
duncanmayes is offline   Reply With Quote
Old 06-03-2006, 11:30 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
Did'nt think plastic could squeak?
pull off the panels and run a ring spanner over all bolts in the doors and check all the plastic srews/clips are in good nick.
also give the door lock mech a grease and also grease the hook thing(thats the new tech term lol)
the door locks onto!....check for any bent or dry rubber on the top of the door trim that guides the window ...glass will squick so make sure its not rubbing
hope this helps.....good luck mate
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-05-2006, 10:35 PM   #3 (permalink)
[quote=cuzman]Did'nt think plastic could squeak?
hope this helps.....good luck mate[/quote
Thanks much!
I'll try them out.
Squeak from brake pedal.. Novice_cardude Camry & Solara Lounge 12 04-12-2006 06:12 PM
Weird smell inside my car.. ptycamry Camry & Solara Lounge 11 01-18-2006 07:46 AM
Changin Inside door handle for GEN 3.5 RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-19-2005 09:24 AM
Squeak!! floramar Camry & Solara Lounge 1 09-28-2005 09:40 PM
suspension squeak and groan on 95 camry 95camry 3rd & 4th Generation (1992–1996 & 1997–2001) 5 12-29-2003 12:22 AM
