Okay, thanks for the clarification. The reason why I wanted to see is because you could click the gear back a couple of teeth on the AFM sensor to lean the mixture out and provide more power and better throttle response (because Toyotas are jetted very rich form the factory).
I'm still all new to the EFI tuning scene. I had no clue that MAF and AFM were the same thing. I though MAF used the electronic sensor inside the intake whereas the AFM used some sort of air vane to control a potentiometer. Well, atleast now I know
BTW, do MAP based sensors get fouled when using a K&N filter? I bought a CAI setup with the K&N filter on eBay before I was enlightened about the flaws.
Just wondering, is there any way to give the same effect as the AFM trick to improve the throttle response?
