93 rolla - tail lights won't turn off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2006, 07:57 PM   #1 (permalink)
View island cruiser's Photo Gallery
Red face 93 rolla - tail lights won't turn off
hi all,
just got my car on the road again and the brake lights stay lit with key out now.
looking under the dash at the switch at top of the pedal it seems to be engaging as it should. any ideas? for the moment i disco'd batt ground...
which fuse is for the lights? it would be easier to pull that than fussing with the battery everytime I park - the cover to the kickpanel box is missing and my Haynes is pretty useless.
mahalo
93 Corolla - 1.6L, surf racks, lots of dents
island cruiser is offline   Reply With Quote
Old 06-04-2006, 10:25 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
disconect the brake switch...see if that turns them off?
Or for a quick fix disonect the power to the brake lights at the globe and use the parkers for brakes during the day?
my ae92 has the main fuse box on the right side of car and the fuse is 15 amp and on the top rear most...hope this helps
i reakon its the brake swictch...
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-05-2006, 06:51 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
my brake switch broke and did that a couple years back. The cheap replacement from Autozone is a cheap piece of crap, but it works. if you have moneyt burn, maybe OEM would be better. It just did not line up as nice and was slightly different. Also crawling up under the dash realy trul sucks donkeys
retiredat44 is offline   Reply With Quote
Old 06-06-2006, 01:14 AM   #4 (permalink)
you said it. once I have time to remove the lower dash parts i'll mess with the switch.
but what fuse should i pull for the lights in the meantime?
Old 06-06-2006, 02:10 AM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Other bulbs will run on that circut, I would just disconnect the battery when ever you park the car.
Or failing that remove the offending bulbs.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
93 previa interior lights don't work Mr Tode Previa Forum 2 04-15-2005 11:07 AM
Lights wont turn off... Lachean MR2 Forum 5 01-09-2005 05:15 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
Solara Tail lights ghinla Solara 3 07-10-2004 04:09 AM
Stupid and Quick Question:Dash lights and tail lights cosmicbutthairs Archived Corolla threads 6 07-27-2003 11:01 AM
