Replacing the radio on a 1996 DX Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2006, 08:25 PM   #1 (permalink)
View djjohu's Photo Gallery
Question Replacing the radio on a 1996 DX Wagon
I'm looking to replace the stock radio on my 1996 Corolla DX Wagon with a CD player. Has anyone replaced their radio on this generation corolla and would be willing to share instructions on how to remove the stock radio? It looks like it may be a bit more complex than me replacing the radio in my 1990 Celica.
Thanks!
djjohu is offline   Reply With Quote
Old 06-04-2006, 09:48 PM   #2 (permalink)
View morris's Photo Gallery
If I recall correctly, you first remove two screws form the panel that houses the radio and heater controls. They are below the radio but above the ashtray. Then pull off the heater knobs and pull the panel out (pry carefully if you need to). Unclip the wiring from the hazard lights switch and the clock and set the panel aside. The radio is held in with four screws, then unclip the wiring harness(es) and the antenna wire. That should do it.
morris is offline   Reply With Quote
Old 06-04-2006, 10:12 PM   #3 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
if ya post a pic of ya dash i can run ya through it!
some rollas have srews at the back of the ash tray as well
i can pull out a dash on an ae92 sweet.....
you may need to remove the plastic on each side of the centre console so you can see what your doing with the wiring as well ..
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Gen2 Camry Crew *SIGN IN*!!! userlain 1st & 2nd Generation (1983–1986 & 1987-1991) 435 01-23-2012 04:17 PM
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
FS: 1996 civic hb dx green (toronto gta) EKR Vehicles 0 12-13-2005 09:11 PM
1988 Tercel DX Wagon 4E-FTE Swap Possible [?] Al_88DXWagon Tercel, Paseo, Starlet, and Sera Forum 5 05-01-2005 05:52 PM
