Howling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2006, 08:41 PM   #1 (permalink)
ems
View ems's Photo Gallery
Howling
I have an 05 Corolla and the other day I started hearing a howling noise coming from the front passenger side. The noise only happens when I am going over 30 and is very annoying. The noise does not exist when the car is not moving. I think it is my hub bearing. Any other guesses.
ems is offline   Reply With Quote
Old 06-04-2006, 09:47 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
First check ya door and window seals.... then jack the front up and see if the wheel moves when shaken side to side if its loose eather the bearings are stuffed or need tighning
Also check ya cv joints to make sure ther are no ripes in the boots as the grease may have done a runner?
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-05-2006, 06:59 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
is it the front right brake rotor and brakes worn out and grinding through the disc ?
retiredat44 is offline   Reply With Quote
Old 06-05-2006, 10:12 AM   #4 (permalink)
The terrorist
View Xenon's Photo Gallery
Check your tires, and also check if there are any loose panels from the side or under the car..
My sexy AE92 http://members.cardomain.com/ababan
Xenon is offline   Reply With Quote
Old 06-05-2006, 07:24 PM   #5 (permalink)
ems
I've checked for any loose panels and dont see anything wrong. My breakes aren't grinding either. It is a howling noise. It is very odd. It sounds like a bad water pump but it isn't the water pump because it only does it when the car is moving.
Old 06-05-2006, 08:40 PM   #6 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
that sound like a bad bearin like stated before, have you hit or climbed a curbe with the front right wheel lately?
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 06-05-2006, 08:44 PM   #7 (permalink)
ems
I haven't hit a thing but I think it is the hub bearing. I'm just wondering if anybody has any other guesses.
Old 06-05-2006, 10:09 PM   #8 (permalink)
cuzman's Avatar
Have you checked the bearing yet as above?
Howling sound at 40mph on 2003 Highlander tzimmermn 1st Generation (2001–2007) 2 08-16-2005 07:04 PM
sounds like howling spirit.mp3 amphipri0n Camry & Solara Lounge 4 02-27-2004 03:39 PM
