Oil leaking from drainplug... why/how to fix? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2006, 09:59 PM   #1 (permalink)
View mr.andrew's Photo Gallery
Like the topic states... I have an oil leak from the drainplug. I just did an oil change this afternoon, and it started after that. This was not a problem before. The plug didn't seem to be overtightened, and it certainly didn't seem loose. Why is this happening? How can I fix it?
It is a 1997 Corolla with the 1.6l.
Thanks.
Andrew
97 Corolla... 1.6 litres of FURY!
mr.andrew is offline   Reply With Quote
Old 06-04-2006, 10:03 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
there should be a little gasket that goes over the thread! did you replace it or maybe it fall off ?
if its ther mayby go another half turn but dont strip it ah!
good luck
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-05-2006, 06:56 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
yeah, don't strip it, I had my oil pan replaced because of the oil plug threads bad and it was $300.00 to be replaced by the dealer. I had no choice, it had to be done fast!
retiredat44 is offline   Reply With Quote
Old 06-05-2006, 08:04 AM   #4 (permalink)
I don't think the threads are stripped. I never saw a gasket... but that could be the problem. Is it just like a washer?
Andrew
Old 06-05-2006, 08:42 AM   #5 (permalink)
Dave's
Gameroom cash: $124350
View Dave's's Photo Gallery
Most I've seen are white plastic/teflon thick washer and should be available at parts stores cheap. Often come in a package of 4-6 for a couple of bucks. They tend to crack and harden with age and heat so they need to be replaced once in a while anyway. Heard some do it every oil change. (I don't)
Dave's is offline   Reply With Quote
Old 06-05-2006, 11:47 AM   #6 (permalink)
I fixed it.. bought a new plug and seal. Also used a washer. No more leak. Thanks everyone!
Andrew
Old 06-05-2006, 12:39 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
washer? the plugs seal is what act's like a washer.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-05-2006, 12:57 PM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I have a copper washer in between, no leaks, plus you dont have to replace it that often
Old 06-05-2006, 01:18 PM   #9 (permalink)
Vroom?
freakinbox's Avatar
yea they use copper for break lines, but does it need a texture to squeeze to for it to seal?
Old 06-05-2006, 02:01 PM   #10 (permalink)
Doctor J's Avatar
Gameroom cash: $263390
View Doctor J's Photo Gallery
There is an option to use bonded sealing washer, with 12 mm dia hole.It is basically a steel washer with rubber o-ring bonded to the inner diameter. The rubber compresses upon tightening, seals the surface imperfections, but cannot be crushed because of the steel washer. It can be reused few times. Seems to work great.
Doctor J is offline   Reply With Quote
Old 06-13-2006, 12:02 AM   #11 (permalink)
drive hard n drive fast
tireboy's Avatar
View tireboy's Photo Gallery
Canada oil leakage
i replace mine every 5.000km . theire super cheap . n save ya the grief of oil leaking from the pan plug.......
tireboy is offline   Reply With Quote
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Fuel Pump Leaking Oil retiredat44 Archived Corolla threads 2 06-03-2006 04:38 AM
Leaking oil in the winter semi-charmed MR2 Forum 3 01-16-2006 05:59 PM
Camry Leaking Engine Oil... CamNub Camry & Solara Lounge 5 09-19-2005 05:49 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
