Overheating '92 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2006, 10:44 PM   #1 (permalink)
View rickmadison's Photo Gallery
Hi...,my 92 coroola witrh 175k miles on it is having this overhaeting problem lately. Normally the engine temp stays at around one third of scale while normal driving. Now as soon as I turned on AC, within 10 mins., the engine temp goes well above half level, close to red mark and then come back down little. Even I turned off AC, engine temp. never seems to stay normal (within third of scale) and oscillates in upper half of scale. This is a new thing thats happening this year. I replaced radiator last year. Appreciate your insight on this problem. Thanks-
rickmadison is offline   Reply With Quote
Old 06-05-2006, 10:59 PM   #2 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
the thermostate is stuffed ..ther cheap and easy to replace!
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 06-05-2006, 11:11 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
That's something you should get checked ASAP.
If you're a do-it-yourselfer start by confirming the temp gauge is correct then make sure the fans are both working properly.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 06-05-2006, 11:17 PM   #4 (permalink)
cuzman's Avatar
Good point! make sure the fans work right..usualy if the wire comes loose the a/c fan stays on as an emergency measure....that'll cool her down as well ..but still check the stat
if ya pull it out it should be closed...then put into boiling water..it sould open..
Old 06-06-2006, 02:44 AM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Even the boiling water test can be inaccurate. For such an important a part thats less than $10 I never even bother testing them, I just throw a new one in.
A said above the most likley problem areas are.
~themostat
~themoswitch (controls when the fans come on)
~fan wiring
~coolent level
~radiator cap
Would be strange if its not one of the above.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 06-06-2006, 09:13 AM   #6 (permalink)
Thank you all for replying. I do oil change myself but thats all I do. I will take printout of your replys and show it to a person who usually work on this car and we will go from there. Thanks once again-
just bought a 92 corolla, need help with springs/shocks issues. lifeisviewtiful Archived Corolla threads 5 04-30-2006 12:04 AM
Yet another overheating problem -- 1992 Corolla DX karugs Archived Corolla threads 12 03-29-2005 08:24 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
