removing radiator 95 Prizm - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2006, 04:30 PM   #1 (permalink)
View slonoma98's Photo Gallery
Question removing radiator 95 Prizm
I'm removing a cracked radiator out of a 95 Prizm. I managed to get everything loose, but realized transmission lines run in and out of the radiator. What is the best way to deal with these? If I disconnect the lines will radiator fluid drain everywhere? How can I avoid this? Thanks
slonoma98 is offline   Reply With Quote
Old 06-07-2006, 04:35 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
Place a pan (of proper size) under the connectors and let the oil drain. Pull the radiator. I recently replaced my radiator, only costed me about $90.00 total (including shipping ) on eBay.com But I have a standard trans and did not deal with auto trans fluid. In the past, I did have many large cars that had tranny lines to the Radiator, same thing, just let it drain. The, after it's all back together, check th e tranny and refill it. You might want new fluid to avoid contamination, especially for tranny fluid which must be clean.
retiredat44 is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
iowa prizm PrizmRacingUSA Vehicles 0 07-30-2005 07:25 PM
Removing yellow reflector from Gen 2 Solara michaels_artic_ Solara 7 01-24-2005 02:26 PM
Opinion on Prizm or Corolla Talisman General Discussion 5 09-28-2002 06:20 PM
Geo Prizm or Toyota Corolla Talisman Archived Corolla threads 0 09-24-2002 12:09 PM
