How do bottle jacks come apart? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2006, 07:40 PM   #1 (permalink)
View tashirosgt's Photo Gallery
Anyone know of a web page that shows how a hydraulic bottle jack comes apart?
I have a couple of defective ones sitting in my garage. I'm not promising to fix them , but I would like to know how one would take them apart in order to do so. For example, does the cylinder unscrew from the metal base plate? There is one from a 3.5 Sears floor jack that won't stay up after you raise the load. There is another one from a shop press that won't go down quickly when the valve is opened.
tashirosgt is offline   Reply With Quote
Old 06-09-2006, 12:10 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
post this in general discussion dude.. it has nothing to do with Corollas.
Old 06-13-2006, 03:49 PM   #3 (permalink)
This is a good link, which was given by someone on fedoraforum.org:
http://www.hyjacks.com/H7.HTM
The exploded diagram of the Yasui jack shows the top of the cylinder unscrews. this may be what holds the cylinder to the base. The site also discusses how to refil a bottle jack and what to use for hydraulic fluid.
Old 06-13-2006, 05:55 PM   #4 (permalink)
View toyomoho's Photo Gallery
The cylinder screws into the base. This is what the large cast-in nut is for at the top of the cylinder. Turn the nut or base, but one end of the jack needs to be held firm as in a vise. Drain out all the oil first. They are easy to repair, most likely a bad seal. Test the jack on something before placing it in service to see if holds position over time.
Old 06-13-2006, 07:13 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
they aren't expensive. I would just say buy a new one......
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Correct bottle jack for 84 2wd? blue84 Pre-88 Toyota Pickup/Hilux 1 03-27-2006 06:21 PM
Just Send The Bottle Back MR2Jedi Off Topic 2 02-07-2006 02:41 PM
How Long can you leave nitrous bottle turned on? cman2000 Camry & Solara Lounge 5 07-03-2004 02:46 AM
