AE92: Amp wiring write-up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2006, 07:05 PM   #1 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Hey guys, I've been meaning to get my amp going for a while. Finally today I've started by getting the wiring thru the firewall. First you have to find a hole in the firewall suitable to put the wires thru. Luckily there's one big enough where the AC lines go if you have AC, if you don't its just a black rubber cover. I have both AE92s with and without AC so it made it easy.
Here's the pics.
This is the hole in the firewall, right under the ignitor/wiper motor area, without AC lines going thru.
This is it WITH AC lines going thru, note that you will have to fool around with the wire a little more in order to get it around the AC lines and into the cabin.
Wire goes thru the firewall and under the dashboard by the passanger side footwell.
Took me about an hour of fooling around, mainly with the fuseblock and the battery.. next update, getting the wire to the trunk and finally hooking up the Nakamichi amp.
Old 07-24-2006, 01:18 AM   #2 (permalink)
random0munky's Avatar
View random0munky's Photo Gallery
jeez, I wish I had AC =( < I have a 91 Toyota Corolla 4 dr sedan with a 4afe =( I had 4 gauge running thru dat hole and for me, the wire routing was hecks easy. If I were you, I would get your hands on some fish tape (which I did) and makes the job 5 bajillion times easier. In fact, taking the interior out is the most time consuming process once you get the fish tape. You can get it at your home depot < what I did, or what not.
random0munky is offline   Reply With Quote
Old 07-24-2006, 01:43 AM   #3 (permalink)
Gameroom cash: $134355
it's a better idea to use a knife, cut an X in the middle of the grommet and run the wiring through the grommet..... makes sure that your feet stay dry
Old 07-24-2006, 01:48 AM   #4 (permalink)
KDM is in
REN69's Avatar
BTW, I finished running the wiring to the back already; I never posted any pics because the ones I took were too dark and I'll have to retake them.
The Nakamichi amp is currently pumping two 8s but I might go to a single 10" soon.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-24-2006, 02:06 AM   #5 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Good work.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 07-24-2006, 06:22 AM   #6 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
I went thru the driver side, theres a rubber plug jsut below the power steering column. Im running two 12's ren
Liter is offline   Reply With Quote
Old 07-24-2006, 06:31 AM   #7 (permalink)
KDM is in
REN69's Avatar
pics yo!!
AE92 JDM Folding Mirrors Wiring HELP! TruenoRican Archived Corolla threads 0 02-28-2006 04:24 PM
Open channel on amp / speaker wiring touringcamry Audio, Video, and Security - Tech 5 06-28-2005 12:59 AM
left over parts from canadagts for ae92 CanadaGTS Archived Corolla threads 0 11-06-2003 09:11 PM
stupid question about amp wiring tinman831 Audio, Video, and Security - Tech 1 10-01-2003 10:20 PM
