vvti cover, you will have two 10MM bolts in the front and then two clips closer to the firewall, then the whole cover pops off.... as far as the headlight assembly I believe and dont quote me on this you have to remove the front bumber to get to two screws that are below the headights. Hope this gets ya started in the right direction
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
