i want to put an awd matrix/vice tranny on my rolla xrs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2006, 12:10 PM   #1 (permalink)
View fontukyracer's Photo Gallery
whats ur guys opinion/advice on that...?
fontukyracer is offline   Reply With Quote
Old 06-12-2006, 03:07 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
You'll need the rest of the AWD system for starters, shafts, axles, then probably the whole assembly for the rear wheels, rotors, hubs, etc... not worth even trying unless you got the money.
Old 06-12-2006, 03:42 PM   #3 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
It would be totally useless. Simply put, after spending tons of cash your car will be slower than a base Matrix AWD with 123 hp. The AWD train will increase the weight of the car by 250 lbs atleast and adding the 4 speed auto transmission with tall gear ratios, it will fall below 5500 rpm in each gear and take many seconds just to get into lift above 6000 rpm and fall on it's face once it goes past 2nd gear. Peak HP does not mean anything unless the transmission/gear ratios allows the car to use the powerband properly. Not to mention, powertrain loss on automatics is around 20% as opposed to 12 - 15% on stick shifts. Hence no auto XRS is available. As it is, A 180 HP Celica GTS with 4 speed auto is slower than a 140 HP 5 speed Celica GT.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 06-12-2006, 04:26 PM   #4 (permalink)
Gameroom cash: $147537
Easiest way, cut the body off the Matrix and weld the Corolla body on the chasis.
If you got the money to do the swap, you'll have money to change gear ratio in the tranny and beef it up.
Old 06-12-2006, 10:43 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
ummm if your gonna cut it up why not just buy a matrix
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
Fog lights for a 99 rolla. Where to put ? gspatta@worldne Archived Corolla threads 3 08-18-2005 07:33 PM
FINALLY Got my tranny put in!! can go for antother 400K gen 4 tranny fits in gen 3!! lil_ta 3rd & 4th Generation (1992–1996 & 1997–2001) 25 06-22-2005 09:27 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
2005 XRS...Safe to put in 87 Octane? otamywy Archived Corolla threads 14 03-14-2005 06:44 PM
