big port 4AG injector help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2006, 04:20 AM   #1 (permalink)
View yotatoy's Photo Gallery
Thumbs up big port 4AG injector help
whats up everyone, I have an 87 big port 4AGE with intake, header, full exhaust and disabled EGR. I believe the engine was running lean so I swaped in the small port red top injectors. (tan or beige) I noticed the resistance values of the injectors were way different than stock
big port- 3 ohms
small port- 13.8 ohms
the engine seems to runfine with these injectors although I dont know if it fixed my lean problem or if the ecu can properly control these injectors. does anyone have experience with this or know how the different resistence will affect the injector operation?
Thanks a great deal
yotatoy is offline   Reply With Quote
Old 06-13-2006, 05:54 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
The injectors wont function properly if the Ohm rating is high and the original ones were low. plus you can burn out the ECU.
Old 06-13-2006, 11:51 AM   #3 (permalink)
Gameroom cash: $134355
you can remove the injector box and the smallport injectors will work
however, you don't have smallport injectors..... the smallport injectors are green.... the beige injectors are ~2.5-3 ohm.... the early bigport injectors (single hole blue) are 1-1.5ohm
Old 06-13-2006, 02:38 PM   #4 (permalink)
Are you referining to the resistor box? And I believe you may be mistaken in thinking that I do not have the smallport injectors. they are from a '91 4AG. I measured the resistance value and it read 13.8 ohms, plus it sprays two seperate streams. my stock injectors were green and black and sprayed one stream, with a resistance value of about 2.5-3 ohms.
What do you think is going on?
thank you very much for your help
Old 06-13-2006, 06:45 PM   #5 (permalink)
View C12ESSIDA's Photo Gallery
Bump
They have done studies you know. 60%of the time it works everytime. -=SEX PANTHER=-
C12ESSIDA is offline   Reply With Quote
Old 06-13-2006, 09:44 PM   #6 (permalink)
Bump
Old 06-14-2006, 04:25 PM   #7 (permalink)
View AVANT's Photo Gallery
You need to do the resister box by pass. As you have already found out, their have different resistance. Don't know what you're bumping it for... it won't run fine because the injectors will have a very weak signal (resistance from box and internally). The injectors won't run at the proper duty cycles and it puts extra strain on your electrical components.
Why do you think the engine was running lean to begin with?
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 06-16-2006, 12:34 AM   #8 (permalink)
Thank you for the information, I will have to swap back to the originals. I belive it was running lean because the computer would set a lean code. And also because I increased the engines ability to move air so I wanted to add fuel.
What would you recommend to richen the mixture.
Thanks
6/21 BIG Toyota & Lexus Owners Meet Flipside909 [SC³] Regional Meetings and Events 5 07-01-2003 12:50 AM
BIG meet at SLAPshow on May, 30th in Milford, MA [SMAN] Regional Meetings and Events 7 05-29-2003 02:25 PM
New engine or Rebuild ? Jzs147-RR Archived Corolla threads 12 03-30-2003 11:58 AM
