shuddering on warm idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2006, 05:36 PM   #1 (permalink)
View chunk97's Photo Gallery
Hello,
My 1997 corolla (4 cyl./1.6 L/Automatic tranny)) shudders and almost stalls once the engine has warmed up and the car is in gear (drive or reverse), especially when I have the AC on. Shifting to neutral and turning the AC off helps but I can still detect a few "hiccups". The car also hesitates a bit when shifting from 1st to 2nd gear (from being stopped to starting- i.e. driving after stopping at an intersection). All these signs started about 2 weeks ago and is getting worse (more violent shuddering, stalling on some occassions while idling in gear). Today the "check engine " light came on also. It drives fine when it is already moving (past 2nd gear I think) even with the AC in full blast.
What could be the cause? How much to fix it? I recently got the car and the previous owner probably didn't do any of the scheduled maintenance (60K, 90K, etc.). It has about 138,000 miles on it.
Thanks
chunk97 is offline   Reply With Quote
Old 06-17-2006, 07:58 PM   #2 (permalink)
View JohnO356's Photo Gallery
Go to Auto Zone or Advance Auto and get the code read. I've read that California forces these stores to charge for reading the codes, but I think it's minimal. That will provide a starting point to diagnose the problem. A lot of things it could be.
JohnO356 is offline   Reply With Quote
Old 06-17-2006, 10:19 PM   #3 (permalink)
View Dirtjump9's Photo Gallery
Yeah, get it checked out and have someone read the codes. On the other hand, make sure your idle is not set too low. When I got my Corolla out of the garage in the spring (it had been sitting for a year), the idle was a bit low and it showed the same symptoms as your car seems to have. I adjusted the idle a bit and now it's great!
Dirtjump9 is offline   Reply With Quote
93 4cyl 4x4 won't idle when warm taterman 89-95 Toyota Pickup/Hilux 9 03-27-2006 11:35 AM
99 4-cyl idle air valve removal sixto Camry & Solara Lounge 3 02-18-2006 01:16 PM
Rough idle after warm start lodom Camry & Solara Lounge 4 04-15-2005 11:21 PM
very high idle rpm when it's warm cortez MR2 Forum 4 03-01-2005 08:03 PM
Gen3 warm and cold idle??? BLUEMEANIE 3rd & 4th Generation (1992–1996 & 1997–2001) 10 02-11-2002 08:24 AM
