Ignition Barrel Fault - need help urgently ! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2006, 05:29 AM   #1 (permalink)
View zzzzMARKzzzz's Photo Gallery
Unhappy Ignition Barrel Fault - need help urgently !
Hope somebody can help me. The ignition barrel on my 1999 Corolla turns ok and ignition lights on dashboard lights up ok, however the last part of the turn of the key which engages the starter/solenoid does not work (did intermittantly, but has now stopped).
I have purchased a red starter button from Maplins Electronics & what to by-pass the ignition barrel but do not know which colour wires are needed to connect to the switch.
I want to do this so I can turn on the ignition, then press the button to start the car.
Any help would be really helpfull.
Thanks
zzzzMARKzzzz
zzzzMARKzzzz is offline   Reply With Quote
Old 06-22-2006, 10:01 AM   #2 (permalink)
anyone ?
Old 06-22-2006, 07:17 PM   #3 (permalink)
View toyomoho's Photo Gallery
From what I can tell, the starter motor wire is pin 8 on the plug that attaches to the ignition key. If you look at the plug head on with the indexing slots on top. Pin 8 is the lower left corner pin. The wire should be Black/White.
The ignition barrel can be replaced without taking the switch out of the car. Perhaps the electrical portion of the switch can also.
Old 06-23-2006, 02:29 AM   #4 (permalink)
Many thanks for you r help, however which other wire do I use on the button to go with the Black/White one ??
Old 06-23-2006, 09:44 PM   #5 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
use one side of the switch and I would connect it to ignition wire and the other to the starter side of starter wire.
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 06-26-2006, 09:25 AM   #6 (permalink)
many thanks
HELP! 3SGE BEAMS wiring help needed SoulSearcher Hardcore Tech and Competition 3 02-10-2006 06:29 AM
wiring diagram for rear view mirrors HELP atobe Camry & Solara Lounge 2 08-15-2005 01:28 AM
wiring diagram for gen3 alxch1n16 3rd & 4th Generation (1992–1996 & 1997–2001) 2 04-05-2005 03:27 PM
Wiring layout for a gen 4 needed, ANY HELP DrewsCam 3rd & 4th Generation (1992–1996 & 1997–2001) 1 06-03-2004 03:47 PM
