dam wireing!!!!! fuct!! HELP!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 06:38 PM   #1 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
AE92 dam wireing!!!!! fuct!! HELP!!
ok so i get home and this litttle black box keeps falling down into my pedal area. so i get pissed and i take off the steering wheel panel on the bottom and come to find out its not even connected. someone tried to put cruise control but with a flea market system. (very cheap) it looks like it was an arlam system to. maybe both i dont know. so since its already all cut up and not connected i said fuck it. i pulled it all out and cleaned it up. so now either i killed the batt cause the car wont start. or i took something out that was imporant but none of it was connected so i dont understand. i just unplugled it and test started the car it started then an hour in the process of taking it out all the wires and now it wont start!!!! help please!!!
ED
xrated3345 is offline   Reply With Quote
Old 06-23-2006, 08:43 PM   #2 (permalink)
gts-rated
xrated3345's Avatar
bump!
Old 06-23-2006, 09:42 PM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
ok what year is the car, since you may need to reconnect the started wires if they were cut for a started kill, the wire will be in the ignition harness if you give me the year I will look uo the color....
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 06-24-2006, 05:44 AM   #4 (permalink)
gts-rated
xrated3345's Avatar
its an 89 gts 4age motor thanks dani.
Old 06-24-2006, 08:24 AM   #5 (permalink)
2005ToyotaCorollaS
your starter wire is black/white at the ignition harness, make sure that that wire is not interrupted in any way, and if it is you reconnect it and your car should crank without a problem
Old 06-24-2006, 06:28 PM   #6 (permalink)
gts-rated
xrated3345's Avatar
yea it was a shit battery leaving the door open is what killed it. i only pulled one thing from the engine and so far its not doing anything bad. but now i know so thanx
Old 06-27-2006, 11:02 AM   #7 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Yah probably was an alarm. Found out that the hard way when my 85 MR2 parts car wouldnt start!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Help!. Changing Timing Belt But Cant Get Dam crank pulley and Crank Pully Bolt Off tousi Camry & Solara Lounge 21 04-26-2006 09:58 PM
dam summer is ending......rant Peter Off Topic 18 08-17-2005 11:00 PM
Re - Thinking front air dam??? Mikey21 Camry & Solara Lounge 8 11-14-2004 03:49 PM
AE82 Windshield Dam How Far from edge to fit ? GeeWhizz Archived Corolla threads 0 10-09-2002 03:44 AM
