Recommended Oil? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2006, 08:37 AM   #1 (permalink)
View 98corollaowner's Photo Gallery
Recommended Oil?
Are there any particular oils (eg. synthetics) recommended for 1998 Corolla VE with over 100, 000 miles?
98corollaowner is offline   Reply With Quote
Old 06-24-2006, 08:41 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
I use mobil 1 rally formula 5W-50 on my AE92
Old 06-24-2006, 11:28 AM   #3 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
That's probably too thick for north america though. 5W30 or 10W30 would do.
Old 06-24-2006, 02:29 PM   #4 (permalink)
View dandxg's Photo Gallery
I am putting Supertech Full Synthetic from good old Walmart. $12 for 5 quarts! I did alot of reading on it on the web, it should be good for atleast 7500 miles and cheap too. It is hydrocracked III synth so not as good as Mobile 1, but much better than conventional oil.
On my newer Camry I am going to run Mobile 1 Extended because it is a nicer, newer, more valuable car.Both will run 5-30 year round.
dandxg is offline   Reply With Quote
Old 06-24-2006, 03:06 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
10w 30 like the owners manual says <shrugs>
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-24-2006, 03:18 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
..and I live in finland... its really not too thick, as its the hot viscosity, it would perform as good as 5W-30, but you could use it in even hotter, 10W30 would be thicker than 5W-50 when cold, but 5W-50 would surpass it when hot, whilst the 10W30 would be water, the 5W-50 wouldnt, theoretically atleast.
However, 10W-30 would already be turning into grease in -18C temp, when 5W would be useable in even colder temps. So unless you plan on changíng oils again before winter, stick to 5W.
Old 06-26-2006, 01:40 AM   #7 (permalink)
Default
View twopointfivebar's Photo Gallery
So let me get this straight, you can actually change the different types of oil per season? Or you should stick with one?
From what I'm reading, it sounds like I can use 10W-30 on my '99 Corolla (manual says 5W-30) during the summers, and back to 5W-30 during the winters?
'99 1ZZFE - E110
twopointfivebar is offline   Reply With Quote
Old 06-26-2006, 02:06 AM   #8 (permalink)
KDM is in
REN69's Avatar
Yes.. you got it dude! as far as I know 10W30 is better in the summer as its thicker therefore won't heat up as fast. 5W30 is a little bit thinner and better in the winter as it will heat up faster than 10W30 and will work better at colder temps.
As far as I know in North America, Toyota recommends 5W30 for all year round; the dealer where I go to get my oil change charges more if I want 10W30 in my car. Also from what I have read its better for an older motor to have 10W30 in it for the summer as it won't sip thru the seals as easy as 5W30 would.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 06-27-2006, 02:11 AM   #9 (permalink)
Default
Hey Ren69, if 10W30 is thicker, wouldn't this lower the performance? Cause the car is already slow enough when the A/C is on...
'99 1ZZFE - E110
HELP! Ran without oil due to leak Jakelukas Camry & Solara Lounge 4 08-14-2005 12:33 AM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
Oil pressure extreme drop on 94 4Runner dutchq 4Runner Lounge 4 10-02-2004 09:05 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 12:04 PM
