riding without a thermostat at all....bad or good - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-25-2006, 05:53 PM   #1 (permalink)
View lifeisviewtiful's Photo Gallery
ok now my girlfriend just bought a 92 corolla 4 dr 3 spd auto w/OD. now while flushing the coolant and such, i went to inspect the thermostat because the car is always at a little notch above the C on the engine temp meter and i was checking to see if the thermostat might have been stuck open. came to find out there was NONE there. spoke to my cousin he said that on older cars like this its best to just leave it be replace the rubber seal add some sealant and just let the car run cool like it has been, he said that given its summer time and its hot as hell down here in FL it can do no harm. what do you guys think.....
lifeisviewtiful is offline   Reply With Quote
Old 06-25-2006, 06:25 PM   #2 (permalink)
View JohnO356's Photo Gallery
I agree. With no computer to monitor the temp, you have no problem. If you live far enough south, you won't need it in the winter either.
JohnO356 is offline   Reply With Quote
Old 06-25-2006, 07:13 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
What??
Just put a new thermostat in it, there are no benifits to running with out one. It will be running rich (useing more gas) and will be down on power.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 06-25-2006, 07:13 PM   #4 (permalink)
no computer?? it is electronically fuel injected not carbureted....... it does have an ecu
Old 06-25-2006, 07:26 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it will cause issues with the engine heating up since it lets the coolant through the engine once it heats up enough. For the cost of it, buy one!
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-25-2006, 07:56 PM   #6 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
If your engine doesn't have one, it's not going to self destruct or anything. It's not really bad per se for the engine, other than if you drive the engine hard when it is cold.
However, It will lower your gas milage, and it will take FOREVER for the engine to warm up.
I would reccomend you install one, as they aren't exactly expensive.
HOWEVER, be aware that there might be a problem that the last owner masked by removing the therm. Just keep an eye on things for a couple of days after you install it, and run it good when you do.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 06-25-2006, 09:25 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
that or they were to cheap to replace it. take it this way when I did it at the shop it was so cheap they told me not to worry about paying for it, since I was doing a co-op there
Old 06-26-2006, 11:21 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
A thermostat might seem to be a very simple device, infact it is, however its role in the engine isnt just to keep the coolant inside the engine so that it will warm up can reach operational temperature sooner. That is only part of its duty. its other part is far more critical, its keeping the water pressure in the head at 1 bar. Everybody knows how a pressure cooker works, you keep the water under pressure so it doesnt boil. Thermostat does that by restricting water flow. Now you take away the thermostat, you take away the means of pressurization in the head and you might actually already be boiling the water inside the head, although the radiator is still cool.
Check any professional (not your local autocross ricers) rally team assembled engines, I guarantee they all have either a thermostat or a restrictor plate in the themostat housing to keep the water pressure up in the head. A behind the scenes trick is to make the restrictor such that it raises head water pressure to 2 bars, thats pushing it, but it works damn well. Having no thermostat is just a stupid fad started by ricers.
Old 06-26-2006, 07:36 PM   #9 (permalink)
Alltrack Wannabe
Intersting point.....
However, the whole cooling system is pressurized to ~ 1bar [14.7 psi.].
If I had to guess, I would say it is probably there to slow down flow so the coolant will pick up more heat from the engine [If coolant flows quickly through a system, it will pick up less heat. If it flows slower, it has more time to take the heat from what it touches. Up to a point of course.].
92 Alltrac, 85 PU
Old 06-26-2006, 07:42 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
like I keep saying. Put a new one, not gonna hurt if you do. the temps will mess your engine up if it's always running cool and you push it. But hey your choice, not my car :p
Old 06-26-2006, 07:46 PM   #11 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
just go put one in yourself...
generic thermostat- 10-15 bucks
toyota red- 25 bucks
2 jugs of distilled water --3 bucks
wrench, standard screw driver, and water hose to flush the coolant.
1 hour job for a novice.. 30 minutes if you're quick.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 06-26-2006, 08:46 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
took me like 10 min to change the thermostat. It was the running it to let the coolant cycle through so you can refill it properly that takes 30 min or so
Old 06-27-2006, 10:40 AM   #13 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
This has been beaten around for so long. I still don't know how it ends though... so is it better or worse to just not run a t-stat in the summer?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 06-27-2006, 10:44 AM   #14 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
good if you are doing hard racing all day, bad in the long run with daily driving, esp in cooler temperatures.
WhiteRabbit is offline   Reply With Quote
Old 06-27-2006, 11:51 AM   #15 (permalink)
Resident asshole
Flashmn's Avatar
aaron7, read my post. I'll tell you all you need to know to make the judgement.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
The Good News and The Bad. ECale3 Camry & Solara Lounge 17 04-10-2006 07:54 PM
good or bad prices????? cesiumxrs 1st Generation (2003-2008) 16 12-28-2004 11:31 PM
good or bad ground wire?? cman2000 Camry & Solara Lounge 11 12-07-2004 06:35 PM
good news and bad news phat91camryLE Camry & Solara Lounge 4 11-27-2003 01:20 AM
