How much longer will it last - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2006, 12:49 AM   #1 (permalink)
View BeaterCorolla's Photo Gallery
Exclamation How much longer will it last
My wife's Corolla has bad exhaust valves in cylinder 4. It sputters at idle, but seems fine on the highway. Fuel economy hasn't dropped either. What harm can continuing to drive the car cause? If the catalytic converter goes bad, will it choke the engine? I just want a few opinions so we can decide when to start looking for a new car. Tomorrow? 6 months?
Thanks
BeaterCorolla is offline   Reply With Quote
Old 06-26-2006, 01:44 AM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Keep an eye on the oil level and you should have a fair while.
How did you determin it has bent valves?
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 06-26-2006, 02:40 AM   #3 (permalink)
New 2006 Corolla LE owner
View ToyotaMan1281's Photo Gallery
well on my old neon cylender 4 was going bad. I had to put some special oil stuff in with the engine oil to help seal it or something. It lasted for a little while until i got it up to trade in for the new rolla. You might want to start looking for a new car just in case.
Toyota 4 life!!
ToyotaMan1281 is offline   Reply With Quote
Old 06-26-2006, 11:58 AM   #4 (permalink)
A compression test showed only 80-90 psi for cylinder 4. They may have done a leak down test too to identify the exhaust valves. I don't think any oil additive will help here since it's the valve and not the cylinder rings. Correct me if I'm wrong. It seems so odd for it to go bad with only 150k on it. I'm wondering if the timing belt work done back at 100k could have caused it.
Old 06-26-2006, 02:44 PM   #5 (permalink)
im not sure what the nortmal psi is. but my neon only had 50K most on it when cylender 4 went bad. Thats good american quality for ya. I know the car was a piece of junk lol. But at 150K it does seem odd. Can you have someone replace cylendr 4?
Toyota 4 life!!
Old 06-26-2006, 05:22 PM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
it's hard to say how long something will last after it's been damaged. Will depend how nice you are to the car and if you maintain it I guess.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-26-2006, 06:02 PM   #7 (permalink)
The TN Member
As above its impossible to tell, the head of that valve may fall off tomorrow or next year some time, or maybe never.
But from pervious experence as long as you keep oil in it you should have a few months.
Can you hear ticking?
Old 06-26-2006, 07:02 PM   #8 (permalink)
Vroom?
freakinbox's Avatar
what year corolla is this?
Old 06-26-2006, 07:32 PM   #9 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
BENT valve or BAD valve?
If it is only the valve seat to valve seal that is bad, it should last a while.
If it is an exhaust valve, it will have a hard time though, as touching the seat is the primary way it rids itself of heat...
If the cat get's clogged, it can choke the engine.
It will run, but it will run poorly.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 06-26-2006, 07:40 PM   #10 (permalink)
Vroom?
freakinbox's Avatar
it would burn more oil, no? oil would leak in through the bad valve should puff out smoke when started. I keep asking the year because you could always swap out the engine if it's a 4afe for next to nothing, or even just swap the head.
Old 06-26-2006, 08:25 PM   #11 (permalink)
Alltrack Wannabe
Oil will leak only if
The seal is bad
The stem is bent, warping the seal.
92 Alltrac, 85 PU
Old 06-26-2006, 08:47 PM   #12 (permalink)
Vroom?
freakinbox's Avatar
well depending how badly it's bent would depend if it even seals :s
Old 06-26-2006, 08:57 PM   #13 (permalink)
Alltrack Wannabe
Too badly bent and it won't slide in the guide.
92 Alltrac, 85 PU
Old 06-26-2006, 10:33 PM   #14 (permalink)
The TN Member
When I bent a valve in my mirage its lost alot of its oil because of crankcase pressure, so bending a valve can cause the seal to go bad.
Old 06-27-2006, 02:20 AM   #15 (permalink)
Thanks for the responses everyone. It's a '97 CE with the 1.6L engine and auto. When I did a vacuum test, it was shakey which my service manual said was bad valve guides. The shop I took it to only said that it was a problem related to the exhaust valves. Whether it was the valve or the valve seat, they wouldn't know until they took it apart. The engine doesn't seem to be burning oil, but it definately clunks when stopped in drive. You could say it ticks at idle, and the exhaust putters. Oh, and it stinks of unburned fuel... Ugh, I just hope it lasts until the Miata hardtop convertibles show up at dealers. That's what the wifey wants.
longer lug studs Brando8844 T-100 0 12-12-2005 10:02 PM
Thanks to All My Email Pals MR2Jedi Off Topic 15 10-15-2005 06:19 PM
STUDS.... I need longer ones. Piddy General Discussion 12 06-10-2005 01:01 AM
Longer Wheel Studs Piddy Hardcore Tech and Competition 6 04-10-2005 11:26 PM
Longer bolts for rims? abovethelaw Camry & Solara Lounge 9 02-04-2005 02:36 PM
