V belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2006, 08:09 PM   #1 (permalink)
View andreadebiase's Photo Gallery
V belt
hi,
can someone tell me how to undo the v belt tensioner on a 2004 corolla?
also what type of v belt should i get? if i go to an autoparts is ok or you recommend only OEM parts?
thank you
ps
my v belt is noisy and drives me nuts
andreadebiase is offline   Reply With Quote
Old 06-29-2006, 01:36 AM   #2 (permalink)
View toyomoho's Photo Gallery
Is there a bolt at the arm and a nut at the end of the tensioner? You need to remove the bolt. If you can't get it out, jack the arm up and down to relieve the pressure. Then remove the nut. The assy should come off.
Old 06-29-2006, 05:27 PM   #3 (permalink)
Amber's Avatar
View Amber's Photo Gallery
When you say, undo the v belt tensioner, what do you mean? Are you wanting to take off the belt? Or are you wanting to remove the tensioner?
I (my brother & I) just got through replacing the tensioner. I can explain it either way.
Amber is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 10:06 AM
99 Camry Timining Belt for $179 DeafBug Camry & Solara Lounge 9 03-07-2005 11:56 AM
Help me with correct belt size- underdrive crank pulley for 5SFE cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-24-2005 10:05 PM
non-interference engines?? 90celica General Discussion 13 11-09-2004 11:34 PM
