2006 Corolla LE Factory Sterio! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 10:31 AM   #1 (permalink)
View ezeroc's Photo Gallery
I will get straight to the point. I bought a Skyfi2 XM unit and mounted it to the car. I am using the built-in FM modulator and the sound quality is not that great. I have searched this forum and found that other people are using the USASpec DF-TOY.
The car does not have a 6 disc CD changer (internal or external). Will this work, just take the radio out plug it in and voula! Hook up headphone Jack to RCA Adapter Cable and connect to the Skyfi2.
Is the radio going to have those plugs on the back. I don't want to buy the thing for $60, and take the radio out to find I have purchased the wrong thing.
If there is anything else I could do, or anyone has a suggestion, I am all ears!
ezeroc is offline   Reply With Quote
Old 07-06-2006, 12:27 AM   #2 (permalink)
caddymac's Avatar
View caddymac's Photo Gallery
I personally use the PAC Aux2Car adapter and it works just fine. From what I've heard, you should have a changer port on the back of your radio. Good luck!
caddymac is offline   Reply With Quote
Old 07-06-2006, 12:43 AM   #3 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
you radio is CD changer ready I am almost sure, just look at the signs above the numbers when the unit is on, and it will show somthing like next CD and stuff...... Since you said that you dont have any type of changer in the vehicle right now, you should be good to go...
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 05:20 AM
My 2006 Corolla LE ToyotaMan1281 Show & Share 4 02-12-2006 06:22 PM
2006 corolla LE questions. ToyotaMan1281 Archived Corolla threads 8 02-07-2006 11:21 PM
New 2006 Corolla or Used 2005 Camry thinkharder Archived Corolla threads 7 02-07-2006 06:01 PM
New 2006 Corolla or Used 2005 Camry thinkharder Archived Corolla threads 1 02-06-2006 03:35 AM
