Changing coolant in a 2001 S - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 04:25 PM   #1 (permalink)
View 2001CorollaS's Photo Gallery
Sorry to post such a simple question, but I prefer to do most maintenance myself over our local dealer and shops, especially after recent events.
I went to our local dealer before about changing it and was talking to them, they told me they would use TAP WATER when servicing the cooling systems. So I won't be trusting them. Previously, they messed up 4 times changing a broken door handle. They are hopeless.
So my question is, can I safely change the coolant myself with Toyota Red and distilled water following the procedure in the book? I've done it numerous times on older vehicles, but nowdays I hear tales of air pockets, and nightmare scenerios that require special equipement to do it right. Are these just tall tales to get you to spend $150 for a coolant change or is it REALLY required?
Any input or advice would be appreciated, although the PH for the coolant is perfect (guess Toyota Red is good stuff), I want to get some fresh in there before it does change.
2001CorollaS is offline   Reply With Quote
Old 06-29-2006, 05:27 PM   #2 (permalink)
2005 TRD Corolla
thms05corolla's Avatar
View thms05corolla's Photo Gallery
Well just so you know, Toyota's coolant is supposed to last 100K miles. But if you have already reached that DO IT YOURSELF!!! Its not hard at all and I wouldn't worry about all of those crazy scenarios. Definitely use the original Toyota red fluid and flush everything out. But its definitely an easy DIY project. GO FOR IT I SAY!!
2005 TRD Corolla LE
1.8L 1ZZ-FE
ZZE130
thms05corolla is offline   Reply With Quote
Old 06-29-2006, 05:39 PM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
the only thing I am not sure about when it comes to this. How you go about flushing out the fluid?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 06-29-2006, 05:40 PM   #4 (permalink)
I would assume with distilled water. Like I said, I went to have it done, then drove off in horror from the dealership.
Thanks for the advice. I'll be doing it immediately, thankfully the PH is sill neutral.
Old 06-29-2006, 07:05 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
I didn't know it was "evil" to use tap water ^o)
I know if you had no anti freeze at all you can use distilled water as a temp fix as long as it doesn't get cold it works.
Old 06-29-2006, 07:40 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I've used tap water, no problem in it, just dont use mineral water.
Flashmn is online now   Reply With Quote
Old 06-30-2006, 12:54 AM   #7 (permalink)
Hehe, tap water here is scarey thought, alot of crap I don't want in me or my radiator. The water here leaves deposits that burn out hot water heating elements every year.
Old 06-30-2006, 01:33 AM   #8 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
Just a thought: Distilled water actually boils at a lower temprature than tap water, because of the lack of minerals in the water. But in saying that, when used with Toyota red Distilled water should be fine.
As far as the air pockets are concerned, don't worry too much. Changing the fluid is easy as pie...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 06-30-2006, 03:33 AM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Actually its the opposite. Distilled water doesnt boil easily, because theres no "contaminants" in the water. Its them that cause the boiling to occur.
1996 Camry radiator coolant disappearing? RAV4EVR 3rd & 4th Generation (1992–1996 & 1997–2001) 8 06-21-2006 01:13 AM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 11:45 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 10:03 PM
TB Coolant bypass. CrawlingEye Camry & Solara Lounge 24 09-12-2004 12:03 AM
