Left Turn Signal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2006, 07:57 PM   #1 (permalink)
View nitu_752002's Photo Gallery
Left Turn Signal
I have a 2001 Toyota Corolla LE. The left turn signal sometimes flashes very quickly and the light doesn't come on. Its not always the case but sometimes it is and its only the left turn signal. We took it to the dealer and he thinks its the switch thats gone. Any thoughts on where i can buy the parts?
How much can i expect to pay to get this fixed? Could the dealer be wrong about the switch? Can it be a bad ground or corosion on the socket instead of the switch? I hate cars, they're just a moneypit!
nitu_752002 is offline   Reply With Quote
Old 06-29-2006, 08:17 PM   #2 (permalink)
View JohnO356's Photo Gallery
Did the dealer check the front and rear bulb sockets? The fast flash will occur when you have a burned out bulb or (in your case) an intermittent short, etc. Pull the bulbs and make sure the sockets and the bulb ends are clean. And yes, it could be a broken wire inside the insulation that only makes intermittent contact. Good luck finding that. I'm not a dealer lover, so I'll say that the last thing to check for would be a faulty switch. But, it could be a connection on the switch.
JohnO356 is offline   Reply With Quote
Old 06-29-2006, 11:05 PM   #3 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Could be a bulb or a fuse.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 06-30-2006, 09:35 AM   #4 (permalink)
Canada
Can you tell me how i can get to the lamps? If i had to buy the parts, can you tell me where i can get it in canada or even the US?
Old 06-30-2006, 12:06 PM   #5 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
More than liely the fillament in the front or rear bulbs is loose and sometimes looses contact, its more than likely your bulbs....
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Turn Signal blinking Crash2Camry Camry & Solara Lounge 5 07-27-2005 05:14 PM
Turn signal failing CorollaKen Camry & Solara Lounge 2 03-24-2005 01:26 PM
turn signal malfunction HELP! cycleguy77 Camry & Solara Lounge 1 11-30-2004 02:07 PM
Help turn signal happyvan Camry & Solara Lounge 1 06-09-2004 04:29 AM
Turn signal problem Chris990 Camry & Solara Lounge 3 04-03-2004 12:06 AM
