'97 Prizm 1.6 timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2006, 12:58 PM   #1 (permalink)
View keenyoung's Photo Gallery
My wife just lost the timing belt on our 1997 Geo Prizim. Unfortunately, she tried to crank the engine for several minutes before giving up. Does anyone know if the 1.6 engine is an interferance engine? Or do we have some bent valves?
I don't know how to tell, but I believe it is a 4AFE engine, is that right?
Thanks,
Keen
keenyoung is offline   Reply With Quote
Old 07-01-2006, 11:12 AM   #2 (permalink)
View Spud's Photo Gallery
I believe you have the 4AFE engine.Its the same engine in the Corolla of similar vintage.If your Geo has the 4AFE you shouldnt have any bent valves.
If perfection could be attained it would not be worth having.
Spud is offline   Reply With Quote
Old 07-01-2006, 11:16 AM   #3 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
1997 Prism i a 4AFE engine, which is a non-interference engine. Should be just a matter of putting a new belt on and off you go (to an extent).
But you have to make sure the timing is right. have you lined it all up??
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-01-2006, 06:43 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Hence the reason why its called.. "preventive" maintenance, learn to use it!
You're lucky the 7AFE is non-interferance, otherwise you be looking for a new motor and not a new timing belt.
Old 07-03-2006, 12:17 AM   #5 (permalink)
Yeah, I'm lucky. How do I time it?
Ok, I found a sticker on the distributor that reads 7AFE.
How do I line up the cam pulley with the engine at top-dead center? (Wish I had a manual.)
Thanks,
Keen
Old 07-03-2006, 06:25 PM   #6 (permalink)
View cheesep's Photo Gallery
Check out the Autozone online manual
http://www.autozone.com/servlet/UiBr...rGuideYMMEYear
A Haynes Manual is a good investment. . .
cheesep is offline   Reply With Quote
Old 07-05-2006, 12:01 AM   #7 (permalink)
Yup, shoulda got the Haynes.
But, no time!. Had to have car running today. So, I finish up the job by guessing that the timing marks on the back of the gears should point at each other (just like every other DOHC car Iv'e ever worked on) at TDC. Try to start the car, and.... no compression. Surprise,
I guessed wrong.
So, I took off the distributor cap, and the rotor was no where near the number one plug wire. So,I unbutton the valve cover, and timing cover, again, and pull the new timing belt. Rotate the cams so the distributor points at number one. Where do the cam gear timing marks line up? In mid air. Pointing at nothing.
I guess they're supposed to be straight vetical, but it's kind of a hit and miss operation when they don't actually point at a physical spot. Apparently I guessed right, however, because after I got it all put back together she fired right up and ran great.
Thanks for all your help,
Keen
Old 07-05-2006, 09:37 AM   #8 (permalink)
View tashirosgt's Photo Gallery
There area assembly marks on one side of cam gears that you match when you put the cams in the head. The timing marks are different marks. I haven't a way to check this at the moment, but they might be on the other side of the cam gear,
tashirosgt is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 10:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 03:59 AM
When to change timing belt on 97 1.6L? mr.andrew Archived Corolla threads 4 04-22-2006 01:13 PM
97 Geo Prizm 1.6 Problem ben_g99 Archived Corolla threads 4 08-09-2005 12:10 PM
Timing Belt Change Interval for '97 Tercel 1.5L chuckhammer Tercel, Paseo, Starlet, and Sera Forum 8 04-20-2004 09:37 AM
