help key won't turn in the ignition........ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2006, 09:56 PM   #1 (permalink)
View lifeisviewtiful's Photo Gallery
the ignition key lock cylinder in my 92 corolla went bad, now the key won't turn(the steering wheel is also locked). i am trying to put a new one in, but the key won't turn to the ACC position so i can slip it out and put in the new one.
here's a list of what i did so far:
tried the key jiggle and repeatedly turning the wheel
tried putting wd-40 on the key and in the cylinder
tried using the shift lock override to shift the car in nuetral and repeatedly step 1.
tried pushing in the pin(that releases the cylinder) with alot of force to see if it will break free
got desperate and tried to use a good ole fashion flat head screw driver.
anyone have anymore ideas.
lifeisviewtiful is offline   Reply With Quote
Old 06-30-2006, 09:59 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Um, if you have the key at the acc postition, it's not going to come out...
It has to be at off...
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 07-01-2006, 02:48 AM   #3 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
maybe the tumber is finished. The little slides and springs inside can wear out and if the key is to worn out that you car making copies off it won't help. also if the pieces inside are worn where the key goes in they won't be pulled in enough clearing the cylinder so it can slide.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 07-01-2006, 02:51 AM   #4 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
so what you are saying is that the key is stuck in the ACC position???? In that case alltracman78 correct, it wont come out untill it is in the OFF position..
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 07-01-2006, 02:51 AM   #5 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
Stupid question?:
Did you jiggle and twist the steering wheel while turning the key to off?
..... Are you in park?
....Did you push into the column (with the key) while twisting?
l....just stupid questions..
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 07-01-2006, 04:30 AM   #6 (permalink)
View AVANT's Photo Gallery
Originally Posted by RningOnFumes
Stupid question?:
I was going to ask the same thing...
1987 Corolla FX16 GTS. 4AGE powered.
AVANT is offline   Reply With Quote
Old 07-01-2006, 05:30 AM   #7 (permalink)
View Stellarpunk's Photo Gallery
if your trying to replace the key lock cylinder your going to have to remove the steering wheel. Your going to have to disconect the air bag fuses. Be carful when removing the steering wheel, air bags are dangerous, and very expensive to replace.
Stellarpunk is offline   Reply With Quote
Old 07-01-2006, 06:07 AM   #8 (permalink)
Vroom?
freakinbox's Avatar
yea sometimes if the steering wheel locks you need to pull the wheel in the opposite direction to realive some of the stress on the lock to get the key out. I haven't slept and mis read what you said hence my previous statement ahahah
Old 07-01-2006, 06:55 AM   #9 (permalink)
Alltrack Wannabe
Whoa, whoa.
Disconnect the neg bat terminal.
THEN mess with airbag stuff..
92 Alltrac, 85 PU
Old 07-01-2006, 08:49 AM   #10 (permalink)
i think you guys are a little confused. the car HAS to be turned to the acc position so that i can slip push in the little pin under the lock cylinder and be able to slip it out. right now it is stuck at the LOCK position and will not budge. and NO you do not need to remove the steering wheel i've done this be fore on a 94 corollas and a few camry's the mechanics are all the same, but you have to get it into the ACC position before that little pin will go in all the way for you to slip it out. and also the car does NOT have airbags. at this point i am going to get a drill and a solid drill bit and just drill carfully through the pin all together, destroying it, which will alow me to get the cylinder out........
Old 07-01-2006, 09:03 AM   #11 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
^^ That was my next guess.... Just get the pin outta there and then pull the chamber out.
And guys: to get the chamber out you dont need to remove the steering wheel, just the plastic covers around the shaft.
And also: airbags actually have a backup so that if the battery is destroyed they will still deploy, so removing fuses and battery cables wont do it. There is a certain procedure that is needed, so you dont accidentally deploy them...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 09-27-2006, 07:40 PM   #12 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
nothing new just good info.
diver9000 is offline   Reply With Quote
Old 09-28-2006, 02:43 AM   #13 (permalink)
View 94_Rolla_Guy's Photo Gallery
this happened to my 94 and the guy had to drill out the pin because i split the cylinder with a screw driver trying to mess with it. After it was drilled it just slipped out. My advice go buy 2 or 3 really really good bits. also centerpunch the pin before you try and drill it
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 09-28-2006, 10:32 PM   #14 (permalink)
View silkydraws's Photo Gallery
If it's auto don't forget the d*** PARK/Safety switch on top of the lock cylinders sometimes the cable hangs up and keeps that thing from allowing proper alignment to the cyl. Whenever I'm around digging in there I disable them by making sure they're all the way up and use #9 Kliens on the cable.
silkydraws is offline   Reply With Quote
Turn Key no kick noofa Camry & Solara Lounge 10 04-26-2005 07:32 AM
I need serious HELP!!! problem with key and ignition V6camryTN Camry & Solara Lounge 12 04-21-2005 01:39 PM
Instructions: How to Program Solara Key (2000-?) Phi Audio, Video, and Security - Tech 0 11-24-2004 06:49 PM
key in ignition warning making me mental 88camry le Camry & Solara Lounge 18 06-24-2004 02:00 PM
turn key twice to start car. jamesmetairie Archived Corolla threads 15 06-10-2004 05:01 AM
