garret t20 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2006, 02:33 AM   #1 (permalink)
View Maxpayne124's Photo Gallery
garret t20
alright been looking for what stock toyota cars have been running the garret t20 turbo. trying to find a used one to build a custom turbo kit for my 4afe and trying to find what car had one of these to salvage from. thanks for your help
780tuners.com
corollacustomz.ca
toyotanation.com
Maxpayne124 is offline   Reply With Quote
Old 07-01-2006, 08:44 AM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
You might find one on a 3SGTE, not sure if they were a T20 or a t25. No A series had one if that is what your ater. Also the LandCruiser and Hilux (Tacoma) Turbo Diesels had a smaller Garrett on them...
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-01-2006, 09:02 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
just FIY 3S-GTE's had CT20 turbochargers, which arent garret turbos, which is inferior to a Garrett t03 in all aspects.
Old 07-01-2006, 09:06 AM   #4 (permalink)
Country Hick
thespud's Avatar
^^ Oh, OK. That may have been where i got the T20 from Just forgot they were a ceramic turbo... Thanks for clearing that up for me..
Old 07-03-2006, 07:51 PM   #5 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
If I do remember from my many hours of reading and browsing, I believe DSMs (Talon/Eclipse) come stock with T25's. Check your local wrecker, it's a little bigger, but I don't remember when that is a bad thing. You could also pick up the same turbo used off many of the Nissan boards from a SR20 redtop, or even a T28 off of a black top. I was also going this route, but with a GZE long block and ECU.
Kr0n1k is offline   Reply With Quote
Old 07-03-2006, 08:03 PM   #6 (permalink)
The TN Member
View punter's Photo Gallery
most 3sgte's run a ct26 which is ceramic, the wrc spec one runs a CT20B which is steel. The caldina (the lateset 3sgte) runs a CT15B, I don't know if this is ceramic or steel.
The CT20B is by far the best turbo and can push out 18psi+ on a 3sgte
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 07-04-2006, 12:46 AM   #7 (permalink)
the most boast im thinking of ever running is about 6psi ....
780tuners.com
corollacustomz.ca
toyotanation.com
Old 07-04-2006, 12:55 AM   #8 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
Then a used/rebuilt t25 is the way to go. Easy to find and should run you no more than $150 USD. Just make sure there isn't any play in the shaft and that the turbine spins freely and you're good to go.
Old 07-04-2006, 12:26 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
I'd go with a T03, its a bit bigger, plus they're dirt cheap, got mine for 30bucks without shaft play.
Old 07-04-2006, 01:51 PM   #10 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
If he's only running 6psi, wouldn't it be a bit overkill? I'd worry about the 1.6 spooling up that large of a turbo. But I am open to correction on that.
Old 07-04-2006, 02:17 PM   #11 (permalink)
Resident asshole
Flashmn's Avatar
its about the A/R actually. A T03 like mine which has a .48A/R on the turbine side will spool up quite quick. Having a turbo thats too small is worse than having one thats too big.
Old 07-04-2006, 07:57 PM   #12 (permalink)
what cars used to run the t03 or t25?
780tuners.com
corollacustomz.ca
toyotanation.com
Old 07-04-2006, 10:16 PM   #13 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
Got ya flash. Completely forgot about that factor. T25--> Eclipse/Talon turbo models (obviously) 95-98(or 99?). Dunno bout the T03 and too lazy to look it up right now, but I'm gonna take a stab and say late 80's early 90's 300ZX Turbo.
Old 07-05-2006, 03:51 AM   #14 (permalink)
Resident asshole
Flashmn's Avatar
Saabs in general, some fords and I think some mitsus have them.
Garret T3 Turbo? Jake25 Archived Corolla threads 8 12-13-2004 08:37 PM
Celica T20 Cabrio Mone Celica Forum 3 08-20-2004 03:32 AM
garret t28 turbo toyotaholic Hardcore Tech and Competition 5 06-11-2004 05:51 AM
FS: CT26 upgrade to Garret T04E, cheap! celica_speed Supra Forum 2 03-07-2004 11:49 AM
Whats better ? CT26 or Garret T28 PoObAa MR2 Forum 7 12-13-2002 12:23 PM
