Rear Wheel Bearing Problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2006, 08:48 AM   #1 (permalink)
View andylphoto's Photo Gallery
My wife's Corolla has a noise coming from the rear. It first manifested itself as a "pulsating" rubbing noise, but only when braking. Then I started hearing it faintly when making a hard turn, even when not braking. At this point, I was still thinking brakes, because it was definitely louder when braking. The noise is also related to the rotation of the wheel--i.e. frequency decreases as the car slows down.
I popped the drums off, and the brake shoes DID need replacement, so I went ahead and replaced everything and had the drums machined. Put everything back together, and the noise is still there. Possibly even a bit louder. So my first thought was that one of the drums was warped, because of the pulsating, but the shop assured me that if that was the case, having them machined would have removed any warp.
Is it possible that this is a wheel bearing going bad? I did check for play when I had the rear end up, and there didn't seem to be any play in either. Thanks in advance for any suggestions.
EDIT: I should add that it's a 2002 Corolla S, so it has the sealed bearing/hub assembly.
andylphoto is offline   Reply With Quote
Old 07-01-2006, 09:10 AM   #2 (permalink)
Country Hick
thespud's Avatar
View thespud's Photo Gallery
That sounds like it could be the bearing going bad... Could it also be a bouncy shock absorber?
- 2001 AU Ford Fairmont Station Wagon (The Family Taxi)
thespud is offline   Reply With Quote
Old 07-01-2006, 10:55 AM   #3 (permalink)
View tashirosgt's Photo Gallery
You shouldn't trust your ability to judge the location of a noise too much. Did you check the brake on the the the other rear wheel? Also check the front wheels.
tashirosgt is offline   Reply With Quote
Old 07-01-2006, 02:02 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
try jacking the car up and wiggling the wheel. IF it moves around the wheel bearing is finished.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
rear wheel well traps dirt ToyotaToday Camry & Solara Lounge 6 04-10-2006 08:48 AM
Rear wheel alignment problem on 2004 corolla S Fv53 Archived Corolla threads 1 02-19-2006 07:50 PM
94 Celica rear wheel bearing Sawyer Celica Forum 5 01-14-2006 04:35 PM
Rear Wheel Problem JIMMYBOY Camry & Solara Lounge 0 08-26-2005 08:07 AM
IS 300 rims on a 4cyl gen 4 98 camry tallassazn 3rd & 4th Generation (1992–1996 & 1997–2001) 23 11-06-2003 08:34 AM
