seatbelt tensioner...? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2006, 07:34 PM   #1 (permalink)
gts-rated
xrated3345's Avatar
View xrated3345's Photo Gallery
AE92 seatbelt tensioner...?
ok so im 99% sure i need a new one. so it dosent retract back almost at all and i pull it too see if it stops you know in case of emergengy it dosent click at all it just gives. yotoa or junkyard? or car part store like autozone? but then dosent that bolt that holds it down at a certian torqe? id think so right? ne1...?
xrated3345 is offline   Reply With Quote
Old 07-01-2006, 07:39 PM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
New is best for something like that.
It's the drivers side, right?
Well guess which one gets the most wear.
And guess which one in the junkyard car[s] has the most wear....
In addition, usually when you have an accident bad enough to junk the car, the dr seatbelt is "used", and no good.
I wouldn't bother with Autocrap on this....
The bolt does have a certain torque, but if you can loosen it, you can tighten it at least as tight....
Or buy a cheap T wrench.
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 07-01-2006, 07:55 PM   #3 (permalink)
gts-rated
xrated3345's Avatar
so just get a new one from autozone. thanks. the seats are gone to shit to i need new ones but thats another post lol.
seatbelt rattle solution Gen. 5 brazilgoal Camry & Solara Lounge 4 03-04-2012 01:45 PM
Passenger Seatbelt Light Confused Pooka 1st Generation (1998-2003) 6 01-10-2007 06:28 PM
1988 Toyota Camry V6 Seatbelt Issue Spencerc 1st & 2nd Generation (1983–1986 & 1987-1991) 4 10-24-2005 11:49 PM
Replacing Serpentine Belt and Tensioner mbd Archived Corolla threads 4 08-30-2004 10:07 AM
98 Corolla Belt Tensioner kevinp Archived Corolla threads 1 05-19-2004 04:52 AM
