Oil Capacity 2002 Corolla LE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2006, 07:48 PM   #1 (permalink)
View ATHiker95's Photo Gallery
Question Oil Capacity 2002 Corolla LE?
I just bought a used 2002 Corolla LE - no manual in the car. Can someone tell me the oil capacity (w/ and w/o filter)?
Thanks!
Mark
ATHiker95 is offline   Reply With Quote
Old 07-04-2006, 03:02 PM   #2 (permalink)
View tech8's Photo Gallery
Capacity -
Drain and refill with oil filter change: 3.7 liters (3.9 US quarts, 3.3 Imp. qts.)
Drain and refill without oil filter change: 3.5 liters (3.7 US quarts, 3.1 Imp. qts.)
tech8 is offline   Reply With Quote
Old 07-04-2006, 05:38 PM   #3 (permalink)
Excellent, just what I needed. I had taken it into Walmart and noticed that they just slapped 4 qts of oil in it and let it go at that. That wouldn't be much of an issue, except they are always in such a hurry there, that they don't give the cars much time to drain and thus when I showed up to claim the car and checked the stick, I noticed it was about .4 of a quart overfull. Don't know if that causes problems, but I made them drain it out.
Thanks!
Mark
Old 07-04-2006, 06:30 PM   #4 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Well, the problem is the way Toyota designed thier car engine oil pans.
The drain plug is on the side of the bottom, not exactly on the bottom.
My guess is they wanted to make sure it wasn't ripped off [the plug] if you drive over something.
Regarless, to completely drain it [and even then there is a bit left] it takes a good 15-20 min for it to stop dripping.
What I do on my Celica is instead of putting it on the lift, I jack it up in front as high as I can possibly get it, so it drains as much as possible.
But half a quart high won't hurt anything.
If you go too far, it will raise oil pressure, causing seals to leak [eventually].
92 Alltrac, 85 PU
alltracman78 is offline   Reply With Quote
Old 09-19-2006, 01:57 PM   #5 (permalink)
View SubaruWRXMike's Photo Gallery
bump can someone tell me the oil capacity for 2005 corolla is it the same? i have to do my sister's car and dont know where the manual is!
SubaruWRXMike is offline   Reply With Quote
Old 09-19-2006, 02:56 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
yes it would be the same.. same motor. And please don't go to Walmart to get your oil changes.. I can see going there for tires, but for oil changes and service?
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
2006 4 cylinder 4X4 oil capacity slipshod 2nd Generation (2005+) 1 05-13-2006 12:11 PM
corolla LE 05 or camry LE 2000 paulafilipina Archived Corolla threads 6 02-15-2005 10:16 AM
20W-50 or 10W-30 Engine oil for 04 corolla? drstillpatient Archived Corolla threads 20 11-29-2004 12:41 PM
Synthetic Oil for the Camry 2002 LE V6 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-26-2002 12:45 AM
