Is my clutch going? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2006, 09:13 AM   #1 (permalink)
View b0b0's Photo Gallery
Question Is my clutch going?
Hey guys!
new to the manual transmission. got a quick question...let's say i'm in 1st, 2nd, or 3rd (the lower the gear the greater the effects) and at about 2000-3000rpm. i quickly stab and release the gas, the car will then start jerking.
what's going on? clutch slipping?
Thanks!
b0b0 is offline   Reply With Quote
Old 07-05-2006, 01:11 PM   #2 (permalink)
View JohnO356's Photo Gallery
What speed are you moving? Any standard shift vehicle will do that if you are moving too slowly for the gear you are in, and the engine will probably die. If you haven't driven a stick before, maybe you should ask a friend for some pointers.
JohnO356 is offline   Reply With Quote
Old 07-05-2006, 01:20 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
you will know that you clutch is slipping or going when you are on the gas...car revs up but its not moving...seems like what you are doing should cause the sputtering once you are off the gas....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 07-05-2006, 01:51 PM   #4 (permalink)
well, it is very noticable at slow speeds, but this still occurs at 2nd gear 2000-3000rpm? so 30-40kph? i believe?
i've driven stick before and didnt really notice this in those cars....maybe because i've only driven for like 10mins at a time
but according to MRQturbo i guess my clutch is not going out
Old 07-05-2006, 04:02 PM   #5 (permalink)
Exhaust Time!
91_CorollaWagon's Avatar
View 91_CorollaWagon's Photo Gallery
My 91 wagon is a stick, and it happened to me when I first drove it....At abouut 3000 RPM's im 2nd gear, if i just stab the throttle, the car will jerk a coupe times, then take off. Its the way you are pressing the gas in those gears, and how high the RPM's are. If the Engine speed is high already, and you are in a low gear like that, the car will jerk. If your clutch was going out, or slipping, the car will not move, but the engine will scream. Its the way yo are driving. When i started I always did that, but once i got the hang of stick, i sometimes do it, but not as much as when i started out.
John
[IMG]%3Ca%20href=%22http://forums.rpmplanets.com/vbpicgallery.php?do=hall&u=506%22%3E[/IMG]
91_CorollaWagon is offline   Reply With Quote
Old 07-05-2006, 04:53 PM   #6 (permalink)
cool! good to know, i really gotta get better at this stick driving =)
Old 07-05-2006, 05:02 PM   #7 (permalink)
Exhaust Time!
Haha, I just started like a few months ago, but im still rusty, and i need to learn alot more. I lose myself at times, and I cant even pull off a decent speed shift.
John
Old 07-05-2006, 07:13 PM   #8 (permalink)
Do'er of the Nasty
Kr0n1k's Avatar
View Kr0n1k's Photo Gallery
Are you talking about a sort of lurch? I know in first gear with an fe, it lurchs forward a bit when you let off the gas quickly after reaching about 3500 rpm, but this is pretty much true if you downshift into a lower gear from any gear and just let off the gas, espically within the cars powerband. I guess I don't know what you are really talking about, but just trying to give some insight. I don't even think about shifting anymore. I would say its most likely driver, I certainly wasn't any good for the first 6 months.
Kr0n1k is offline   Reply With Quote
Old 07-06-2006, 09:49 AM   #9 (permalink)
yea, i guess it is a lurch....i got my friend who drives manual to take a ride with me and he told me it's normal....
so it's just the driver hopefully that'll be fixed over time....haha
Clutch problem, seeking help. blueapple Celica Forum 0 01-21-2006 12:17 AM
UPDATE: Clutch problem canadianae92 Archived Corolla threads 2 10-29-2005 05:13 PM
My clutch has started slipping and I dont know why REAPER STRAIN Camry & Solara Lounge 55 09-19-2005 07:47 AM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
