2005 Corolla S Tire Size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2006, 04:30 PM   #1 (permalink)
View Hoolign1's Photo Gallery
Question 2005 Corolla S Tire Size
I would like to change from the stock tire size of 195/65/15 to a BF Goodrich G Sport 225/50/15. One local tire dealer said this would be no problem. Another local dealer as well as the BF Goodrich site claim modifications to the vehicle are necessary in order for this tire to fit properly. That sounds crazy to me. Anyone have experience with tire size issue? Thanks.
Hoolign1 is offline   Reply With Quote
Old 07-07-2006, 01:13 AM   #2 (permalink)
View arens's Photo Gallery
Going with a tire that wide may cause some rubbing issues. You will be adding about 15mm (approx .6 inches) of width to the inside and outside of the tire. You will want to measure your current clearance on the inside of the tire for starters. If that is ok I suspect you will want to roll the fender lip to prevent any rubbing there.
arens is offline   Reply With Quote
Old 07-08-2006, 01:13 AM   #3 (permalink)
View changsn's Photo Gallery
Since the profile of the tire is lower, your speedometer will read higher than actual...
changsn is offline   Reply With Quote
Old 07-08-2006, 10:53 AM   #4 (permalink)
^^^ Good catch. a 225/55/15 will be much closer in size, but still a little smaller, to the original. 50 series puts your speedo about 4.5% off and the 55 series puts you just under 1% off. This also means your odometer will go up quicker and warranty will run out sooner.
Old 07-08-2006, 11:11 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
you're going too wide for the vehicle and like it was said you might rub the inner/outer fenders. 205/60-15 sounds like a better choice to me.
Here, go play with the tire size calculator.
http://www.miata.net/garage/tirecalc.html
Old 07-10-2006, 08:12 AM   #6 (permalink)
Thanks...
Thanks for the help!
Max tire size for 2005 Camry LEs xpeed 5th & 6th Generation (2002-2006 & 2007-2011) 4 02-02-2005 12:48 PM
tire size echo 2005 velovelo Yaris, Vitz and Echo Forum 5 12-23-2004 11:25 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Wheel size on a 90 Corolla 4 door touringcamry Archived Corolla threads 5 06-07-2004 04:10 AM
