Hi all,
Hoping you can help me track down an electrical problem with my 99 Corolla CE.
A few days ago I went to shift into drive and the shifter was locked. I figured it was a blown brake light fuse because this happened in my 95 4Runner once, but that doesn't seem to be the problem. I have pulled every fuse I could find and none seem to be burned out, so I'm starting to question my own vision... I looked in the fuse box by the battery, the one up in front by the headlight, and the one under the steering wheel behind the change box.
All the symptoms:
Cannot shift out of park without depressing the over-ride button.
Brake lights and rear tail lights do not work, but turn signals do work.
Console (speed/gas meters) backlight does not work.
Power windows do not work.
Power locks do not work.
Headlights, turn signals, radio, dome light, blowers, a/c, etc all work fine.
The tail light bulbs dont appear burned out either.
Any suggestions?
Thanks in advance,
Russ
